Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree5Likes
Thread: electrical issues HELP
    88 vl
    Jan 2012
    Pottsville
    Default electrical issues HELP
    When I bought the car I noticed it had no high beam and the fuel gauge didn't work.
    Can I do anything myself to find the problems to my situation???
    My car is a 88 vl sl
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    high beam would need a new bulb probs maybe a melted fuse but start from the beginning and work your way back
    with the dash give a tap where the fuel gauge is, mines been sticking alot lately and thats how its come good although could be the float in the tank
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    my fuel gauge sticks as well works when it wants too, i whack every now and then and it works for a while.
    high beam could be no or broken globes, blown fuse, relay or the indicator stalk switch. use a light tester and trace the current back.
    Nobody wants to play with me
    drewVHSS's Avatar
    drewVHSS is online now Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    before i pulled my VL off the road and stripped it it had the same faults but a few extra ontop.
    I had no fuel gauge, no dash lights, no parkers or headlights would work. And no interior light.
    I checked the fuse box and found it kept blowing a blade fuse, turned out i had a short for the interior light in the B pillar and it kept killing everything else above each time i turned the headlights on.
    HTH
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    My speedo sticks lol I just tap the gladd/plexi glass cover on the front and it springs back
    |8|7|R|B|3|0|V|L|
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    also known as Perspex :P
    high-beams i bet my left nut its the fuse block has melted where the high-beam fuse goes.
    fuel gauge.. as stated above. Sticky gauge, or intank float which is on a variable resistor is failing. could b something stupid like a loose plug at the tank
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    I am preying for your left nut nath,
    although I think you are right, it just may well be a fuse or the stalk switch.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    88 vl
    Jan 2012
    Pottsville
    Cheers everyone thanks for the help the fuse block is all melted.
    What can you do to fix melted fuse block I'll add some pics of it tomorrow?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    88 vl
    Jan 2012
    Pottsville
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    88 vl
    Jan 2012
    Pottsville
    holden vl sl wagon
    Dec 2011
    gold coast
    same thing happend to mine the ####er melted both headlight and high beam could someone help me with rewiring both????
  15. #15
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    just undo the 2 screws holding down the main fuse rail and carefully pull it up .... wire in a fuse in between the 2 wires which the fuse connects. u can by inline fuse holders and fuse cheap man. make sure your not changing the fuse rating...
  16. #16
    holden vl sl wagon
    Dec 2011
    gold coast
  17. #17
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    My fuse box is melted on the high beam side, but my beams work fine, I'm guessing the previous owner of mine chopped the wires like Nath said & went inline
    |8|7|R|B|3|0|V|L|
  18. #18
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    inline is the easiest and cheapest way and does no comprimise any thing.
    PLEASE DISSCONNECT YOUR NEGATIVE BATTERY TERMINAL before you start undoing wires in the fuse box.
  19. #19
    holden vl sl wagon
    Dec 2011
    gold coast
  20. #20
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
  21. #21
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    cmon really.... 1 end of the wire twist it with ur inline fuse wire and solder and heatshrink or tape it and then the other end of wire do the same so u have a "Inline fuse"
    or get wire joiners
  22. #22
    few commodores
    Feb 2011
    victoria
    another option for the headlight wiring.
    mine has a similar problem, the fuse isn't blown but it's melted and become 1 with the fuse box, seeing it still works i decided to take some load off it.
    I went and bought some nice heavy wire that will handle 30A and some female spade plugs to suit the wire thickness
    Cut the high beam feed wires from both headlight plugs (body wiring side) and put the heavier gauge wire between them and feed the lose end near the battery.
    Make sure the joins and passenger side wire that is cut are well insulated, I used a few layers of heat shrink.
    At the battery I placed a relay, Used the green H/Beam wire as the trigger on the relay and feed the relay straight from the positive on the battery.
    This has worked extremely well and if anything less voltage drop and brighter H/Beams it's even running 400Watts without an issue, you can't do that with stock wiring.
    I never got around to it but was going to chop the gnd wires and screw them straight to the body to reduce the resistance and voltage drop more..
    electrical issues HELP-splice.jpg electrical issues HELP-plug.jpg electrical issues HELP-insulate.jpg electrical issues HELP-schematic.jpg
  23. #23
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  24. #24
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by detox_nath83 View Post
    wonder what the spiders think of ur mod
    |8|7|R|B|3|0|V|L|
  25. #25
    few commodores
    Feb 2011
    victoria
    They keep the thieves away when they're trying to hot wire it
  1. Help! VZ has severe electrical issues
    By full throttle in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-01-2011, 06:11 PM
  2. vs electrical issues after amp install
    By crawfy in forum Electrical Wiring / Questions
    Last Post: 25-11-2009, 12:24 PM
  3. VS Wagon Electrical Issues
    By churrell in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2008, 08:52 PM
  4. Electrical (and possibly other) issues with my VR
    By Rad-Man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 08:57 PM
  5. Electrical issues on VN Berlina
    By jpetrou in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2006, 08:26 PM
