Hi guys need to know correct place to set afm at ie which point to put multi mine says 1 to six 6 being air box end have set it to 3.5 between 6 and 4 but alas still has idle mis before u ask afm new, new internal pump ,new leads plugs new coolant temp sensor cas is six months old no fault codes on ecu will give aac a clean up an try again
have a look in my sig below on how to set the afm (Troubleshooting Rb30)... should not have been tampered with but put it back to factory spec..... it could be something else as well
Found setting on calis fourm and its slightly better still has pop In it though is getting rather anoying just can't get it running like a vl should will bring home timimg light and try that Wat u guys reckon?? Calais forum said with afm unluged should be 384 ohms did that
its something else then.. no air leaks in the intake piping?
