any one know if the vl sill covers come off??
where are these sill covers located?
the sill that runs under both doors on each side the cover just under your doors i want to repaint mine but unsure of getting off
scuff plates? the plastic bit that holds the carper down? 1 in each door
na man, u knw the sill u jack ur car up on running below the door , the cover for that
must have skirts on it then, most vl's only have a sill and that's welded to the car..... if that's the case they're probably screwed on.
does yours look different to this?
Im guessing you have calais skirts?
Those?
|8|7|R|B|3|0|V|L|
i rekon the calais skirts too,, they are on with clips like little pins coming out the sill
Just a quick thread hijack, I was thinking of getting these for my vl, would they suit it, or even fit? Mine isn't a Calais btw
|8|7|R|B|3|0|V|L|
doesnt need to b man..... same sills only difference is the pins arnt there.. for the lower skirts,,, use screws problem solved
Cheers bloke, now to source a set...
|8|7|R|B|3|0|V|L|
