Results 1 to 20 of 20
Thread: Vl bonnet release spring
    Vk 5LTR
    Oct 2007
    Melbune
    Default Vl bonnet release spring
    hey guys im having trouble closing my bonnet and noticed the release spring is sitting in the middle where it should be sitting to the far left. any know what could cause this. spring stuffed ???
    few commodores
    Feb 2011
    victoria
    comparison pic below, that looks like it has somehow bent towards the top of the pic... never seen that before, thought spring steel fractured and broke instead of bending.... replace the catch mech, to me it looks like it's about to break.
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    Replace your bonnet cable [they come with the handle], and also jam a screw driver down there when the bonnet release is pulled, then let go of the release and check where the spring sits, because me and my dad got my bonnet stuck down due to stuffing with the spring, and we ended up bending the metal thing [in your pic] into more of a curved shape and it fixed it. We also got a new release cable because my old handle was snapped so it wasn't pulling all the way
    |8|7|R|B|3|0|V|L|
    Vk 5LTR
    Oct 2007
    Melbune
    hey guys just replaced the cable today. because i forced the bonnet shut yesterday and just to open it and snapped the cable
    few commodores
    Feb 2011
    victoria
    with the angle in your pic i wouldn't try to straighten that, it's already weak if it's bent to 45 degrees, maybe check other model to see if they're compatible if you can't get a vl one.
    Vk 5LTR
    Oct 2007
    Melbune
    few commodores
    Feb 2011
    victoria
    yeah the actual mechanism you have pictured, compare the angles to the pic i posted, didn't know they were that cheap, never had to replace one.
    be quite annoying if you straightened it and it snapped a day or 2 later, be there for a while trying to open the bonnet then.....
    Vk 5LTR
    Oct 2007
    Melbune
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    haha yep... i snapped my cable on sunday lol.. got one coming from perth as nobody could get one for me from the usual shops.. so i have the old cable hanging out the bonet as a manual release lol...works gr8
    Vk 5LTR
    Oct 2007
    Melbune
    few commodores
    Feb 2011
    victoria
    shouldn't need to remove the nose cone, maybe the grill, should be quite accessible from underneath behind the bumper, couldn't see the ac condenser in your pic so even just pull the radiator out for access (if you don't have ac that is)
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Quote Originally Posted by Sik_Cordz View Post
    haha nice. i bought mine from rarespares $51
    Same lol, but $50 :O SAVED A DOLLAR!
    |8|7|R|B|3|0|V|L|
    Vk 5LTR
    Oct 2007
    Melbune
    hmm ive got the rad out at the moment and yup no a/c ill try get it out without removing the nosecone
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  15. #15
    Vk 5LTR
    Oct 2007
    Melbune
  16. #16
    Vk 5LTR
    Oct 2007
    Melbune
    well ive managed to keep the spring in the correct spot. but when i close the bonnet. the spring and pin isnt sitting centre in the rad support
  17. #17
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  18. #18
    few commodores
    Feb 2011
    victoria
    the grove isn't damaged from the bent/damaged one? allowing the replacement to sit to far into the center
  19. #19
    Vk 5LTR
    Oct 2007
    Melbune
    well after a lot of mucking around with the pin on the bonnet. its closing and opening perfect. thanks for all the help guys
  20. #20
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nice work man good too c all sorted
  1. Bonnet release catch spring need help
    By Subliminal Kriminal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2011, 05:10 PM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. Bonnet won't release
    By JoelG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2007, 02:57 PM
  4. bonnet release
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 12:15 PM
  5. HELP - VN bonnet release
    By stunnd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2005, 10:45 PM
