Results 1 to 25 of 25
Like Tree7Likes
  • 1 Post By Lazza78
  • 1 Post By Reaper
  • 1 Post By Munz
  • 1 Post By Sik_Cordz
  • 2 Post By wraith
  • 1 Post By 87RB30VL
Thread: Why put the battery in the boot???
    VL Calais V8 Manual
    Feb 2012
    Christchurch New Zealand
    Default Why put the battery in the boot???
    Just got myself a real nice VL Walkinshaw rep. running a 5l manual out of a 98 SS Commodore running a clubsport management system.
    The issue is the batter is been moved to the boot when the upgrade was done last year so when cold the "Beast" (as my 4 year old boy calls it) starts well every time without miss. Get it up to running temp and it a whole different story.
    It tries to start but just sounds like a flat battery, if i leave it for 30min, still sounds like a flat battery still but will start.
    Car has a new (X large) battery, auto sparkie says it not pulling the amps when hot, standed problem with putting battery in the boot he said.
    Looking at putting battery back under the hood, can anyone tell me why this seems to be the "in" thing with v8's and should i leave it there or move it back.
    Why put the battery in the boot???-317127_2111659875965_1379674799_31773961_2088683375_n.jpgWhy put the battery in the boot???-v8-holden-motor.jpg
    Mates. Beer and COMMODORES that's all that matters.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Only advantage i know if is to improve the weight distribution from being front heavy to slightly less front heavy. However, that assuming everyone drives with an empty boot all the time, which is the part that i think is stupid. If you value your Boot space and don't want to spend double the price on a boot-safe battery BE A MAN and put it back under the bonnet. If u want this to be a track car keep it in the boot.
    Edit : take the boot spoiler off too and you'll save a s_load of fuel and go faster too.... looks like that Walky spoiler must create a shed load of drag.
    Flame suit on from all the Walky fans.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    most ppl do it to remove the ugly thing from the engine bay or for clearance for intercooler pipes etc....
    can u run a thicker gauge wire to handle the amps needed. could b something like this.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    ^ This.
    Battery in boot generally equal tidier engine bay.
    Ronald Reagan (1986)
    Vk 5LTR
    Oct 2007
    Melbune
    hmm well if the car was factory v8 there would of moved the battery due to your airbox sitting where the battery is. factory vl 5ltrs had them in the passenger side. factory rb30 in the drivers side
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Can you check it for error codes. The car not starting when warm has nothing to do with battery unless the battery is stuffe some where it can't breath and is getting charged mega amps making it cook.
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    first Q Ryback is there a negative battery lead running from the block to the battery in the boot(like how the positive lead is running from front to back) or is the battery just earthed in the boot and the engine earthed to the chassis ??
    i found this same issue with a mates car and once running a negative lead from the block to the battery(also have the block earthed to the chassis up front on opp side of engine) the car would start with no issues at all(even after a 20min thrash at powercruise)...
    hope this helps u mate
    VL Calais V8 Manual
    Feb 2012
    Quote Originally Posted by Sik_Cordz View Post
    THanks for this was talking to the builder... It was a factory RB and he thought it was "cool" to have the battery in the boot.
    VL Calais V8 Manual
    Feb 2012
    Thanks guys this has given me food for thought.
    I will have to see how this is earthed, before i go and change things as it could just be a little change to the earth layout.
    SS
    Jan 2012
    Australia
    If its only when hot it will be one of the following.
    Starter motor solenoid is on its way out, Or (and im not 100% on RB's) crank angle sensor or hall effect sensor.
    As mentioned above, double check all your earths, because that might be effecting it a little bit.
    As for battery in the boot, it mostly gets done for clenliness. Ive done it a few times, makes the bay look 100 times better IMHO
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    I'm no expert but.
    People move the battery for space in the engine bay and for a cleaner look.
    If your having troubles starting it, Make sure it's earthed out properly..Maybe run a Negative cable to the engine (if you havnt already).
    I was advised if I had problems starting it while hot that maybe I need to upgrade my earthing..(I don't have a battery in the boot though)
    lol a bunch of others bet me to it.
    Good luck with it man. Nice car btw
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    As above - the usual reason is for weight distribution and/or because there is not enough space in the engine bay. You will need a big cable to start the car as the starter draws a lot of amps when cranking. Being a VL you might get lucky and overload the wiring causing a fire and burn the thing to the ground if you have under spec wire.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Reaper
    Didn't see this comin!!!
    VL + Reaper = H8
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    VL Calais V8 Manual
    Feb 2012
    Quote Originally Posted by Munz View Post
    VL + Reaper = H8
    NICE......
  15. #15
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    You're all idiots!! People do it because it's fully sick race spec bruh!!!! Put the battery in the boot for added 350HP, then wait for v-tec to kick in and you'll be ffullyy siiiiiiiiiiiiiiiiick!!!!
    |8|7|R|B|3|0|V|L|
  16. #16
    Vk 5LTR
    Oct 2007
    Melbune
  17. #17
    holden vl sl wagon
    Dec 2011
    gold coast
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by rb30vlsl View Post
    dont put battery in boot it puts out harmful and flammable gasses!!!!
    Lucky you can get one's that don't.
  19. #19
    VY Berlina V6 / R31 Skyline
    Dec 2008
    VL Theorem right here.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  20. #20
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    ryback- my battery is not in the boot for that reason,i brought a battery holder and mounted it in the engine bay as can be seen on my vl thread.
    also post a thread up of you're vl, reaper will love it lol.
    My VL Walkinshaw replica project
  21. #21
    vy2 clubsport
    Feb 2008
    adelaide
    problem sounds familiar.....
    had a vn ss that once got hot it would not turn over till it cooled down.....put new starter motor in and it was fine like what one guy said up above
  22. #22
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    I hace the same problem in mu vh.same 5ltr engine.. If its cold starts fine once i take car for drive wont crank.... Leace it for fee hours come back and its all sweet
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
  23. #23
    Vk 5LTR
    Oct 2007
    Melbune
    yer its called engine heat soak. same thing in my old vk. did a reco on the starter and fine
    uwishn you got any close up pics of the battery mounted.
  24. #24
    VL Calais V8 Manual
    Feb 2012
    Quote Originally Posted by *uwishn* View Post
    Thanks for this...And nice car
  25. #25
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Lol I want to see this thread posted too for some Reaper Rage.
    |8|7|R|B|3|0|V|L|
  1. battery in the boot of vt
    By vtbandit in forum Electrical Wiring / Questions
    Last Post: 06-10-2011, 06:39 PM
  2. Battery to Boot
    By Sik_Cordz in forum Electrical Wiring / Questions
    Last Post: 10-11-2010, 09:39 AM
  3. Battery In The Boot
    By VKCOMMO in forum General
    Last Post: 12-11-2009, 07:09 AM
  4. Battery to Boot...?
    By lo-rolla in forum Electrical Wiring / Questions
    Last Post: 15-04-2009, 12:58 AM
  5. Battery in the Boot?
    By Tekka in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-02-2006, 06:10 PM
