Results 1 to 7 of 7
Thread: viscous fan clutch
    vl berlina wagon 6cyl
    Jul 2005
    Default viscous fan clutch
    it seems this can eventually fail and may result in overheating on hot days, some say you shouldnt be able to spin the fan more than 1 revolution by hand if the viscous clutch is still OK
    a bloke grabbed my fan, wearing gloves, I might add by hand with the engine idling and stopped the fan but I dont know if this could be done with the clutch still OK
    anyhow I replaced it with a non genuine one, a hell of a job , why are all the clearances so damned tight on the VL?
    with factory air cond of course you get an extra electric fan at the front
    any comments?
    pj
    pj is offline
    VS Executive
    Aug 2005
    With all clutch fans, i usually get the engine at operating temperature, let it idle for 15 30 minutes or so, making sure that the fan should be working, then just roll a newspaper up and put it carefully into it, from the passenger side. If you can stop it, it's usually not doing it's job. Of course the thermostat has to be doing it's job to get it to temperature too.
    VT SS S2 A4
    Aug 2005
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i'm thinking of swapping mine for twin AU ford electric fans. i hear they bolt straight in. don't quote me on that.
    VT SS S2 A4
    Aug 2005
    no, they dont bolt straight in
    You need to modify the housing that they are in, where the filler neck is and also where the top hose goes.
    I have a set of them that I was going to use, but have been recommended by 3 different mechanics to go back to the clutch fan.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by rb26dett
    thankyou, saved me alot of hassle there.
    VT SS S2 A4
    Aug 2005
    It is something that you could do, but you would just need to take your time to make it look good.
  1. vu ute clutch
    By ripper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2009, 10:26 PM
  2. 5.7 ltr Vy Clutch
    By Purplecrewy in forum LSx Development and Modification
    Last Post: 02-05-2008, 10:10 PM
  3. how vr clutch goes together
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 11:34 AM
  4. VH viscous hub
    By jlenon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2005, 09:59 AM
  5. Viscous Coupling -> Electric Fan
    By jetspin_vn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2004, 10:52 PM
