Results 1 to 10 of 10
Thread: removing bottom radiator hose
    vl berlina wagon 6cyl
    Jul 2005
    Default removing bottom radiator hose
    it seems almost impossible to remove and replace the bottom radiator hose on the 6cyl VL without removing both the fan shroud and the fan
    is there any trick to doing this job
    it cant be got at from underneath either it seems
    also I read that theres a baffle in the radiator to cope with the fact that both hoses attach to the same side and that if this baffle drops, the water doesnt go thru the core, resulting in drastic overheating
    executive vt 5.0lt
    Feb 2005
    west suburbs
    VZ Calais
    Aug 2005
    Mackay Qld
    When you fit the hose, put the clamp in a position where you can access it? Got no problem removing mine from the top! Dont have to remove anything!
    VT SS S2 A4
    Aug 2005
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by coolngroovy
    i agree totally.
    VZ Calais
    Aug 2005
    Mackay Qld
    Skinning the knuckles is just part of working on cars! If we dont like it, we can always pay someone else to do the job for us!
    pimpin_calais is offline pimpin_calais
    vs calais
    Jun 2005
    perth
    stock_vl is offline wh internationals?
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    lol. yeh i managed to do it the other week dude!
    although my hand did find it hard im sure you could still do it..
    u mite have to start with a small shifter if the clamp thing has turned and u cant get to the actuall bit for screw driver...
    if you gets me!
    umm out of curiousity!!
    where the hell is the block on the block thats ment to be undone when flushing block and radiator!! its ment to be near a turbo coolant plug?:S or something!
    i couldnt find it. it just stated on the side of the block with a dodgey pic in my manual
    I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Jul 2005
    the drainplug is hard to get at, under the exhaust pipe, helps to remove the wheel
  1. radiator hose?
    By WhiteVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2007, 09:50 PM
  2. FS: Mackay Top & Bottom Radiator Hoses To Suit 5L V8
    By ChRiDDa in forum Parts And Other Items For Sale
    Last Post: 02-07-2006, 01:54 PM
  3. FS: Mackay Top & Bottom Radiator Hoses To Suit 5L V8
    Last Post: 09-06-2006, 07:55 PM
  4. Bottom Radiator Hose
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2006, 11:20 PM
  5. radiator hose
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 08:01 PM
