Results 1 to 6 of 6
Thread: VL 6 cyl power steering pump
    few commodores
    Feb 2011
    victoria
    Default VL 6 cyl power steering pump
    Anyone been able to get parts to rebuild an early vl 6 p/steering pump with the outlet at the front/side? slightly smaller than the saginaw used on 8's, later vl 6's, v6's etc etc
    so far the parts are a bit hard to come by, been searching for a few weeks (the o-rings seals are not a major concern i can find something that will fit)
    The main front bearing easy enough being a 6203
    The bits that are being a pain to track down are:
    The front seal, has a helical pattern for sealing, anyone know the dimension's of this one? GM part #7839589 from what i've found in cross reference listings it has imperial measurements.... doesn't seem right as the shaft measures 19mm with the varier calipers, don't see the point of removing it and destroying it before i can definitely get a replacement. And has anyone just replaced this with a standard seal and had no problems?
    The rear torrignton drawn cup needle roller BH59 haven't given up finding one in surplus but has anyone found something compatible?
    like a BH57 that is shorter and has a lower load rating?
    Holden can't help, rebuild kit number is no longer available.
    At the current point it's looking like it'll be easier to replace the bracket and high pressure line to fit the newer model pump(cheaper design) or just throw in a manual rack.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    vy2 clubsport
    Feb 2008
    adelaide
    If its an old style vernier maybe your reading the measurments wrong? some people who dont know how to use them read them wrong unless you got digital?not saying you dont know how to thoe but it could explain the big difrences?
    few commodores
    Feb 2011
    victoria
    yeah verniers, know how to read/use them but variers cause everyone will get a different reading if they don't use them right.
    VZ Wagon
    Jun 2011
    Brisbane North
    Front seal...
    Any good hydraulic place should have a seal if you can give them the measurements and application. I have always had good success with CDR 07 3889 7822 in Brendale north of Brisbane.
    They have all types of seals up to 5000PSI
    Good luck with the rest
    few commodores
    Feb 2011
    victoria
    that's part of the problem, it sits behind the front bearing and is a smaller outer diameter than the bearing, no way to measure it without destroying it lol.
  1. VT LS1 Power steering pump
    By topdzl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2011, 08:48 PM
  2. power steering pump
    By fattypomba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2011, 08:46 PM
  3. VT power steering pump
    By Choc_4180 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2010, 05:25 PM
  4. Replies: 1
    Last Post: 09-11-2008, 08:18 AM
  5. Wtb In Vic: Vn/vp Power Steering Pump
    By calaiscruzer in forum Swap / Wanted to Buy / Trade
    Last Post: 09-08-2008, 04:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
