Results 1 to 6 of 6
Thread: Air Con
    VN Berlina
    Sep 2005
    Default Air Con
    how do i find out whats needed to fix my air con on my new VL. it dosnt work but yeah where do i look to find out if i need gas some unit for it or if its just buggered thanx
    VR Berlina V6
    Sep 2005
    orange
    VN Berlina
    Sep 2005
    SNY.3LT Guest
    if the air con doesnt work at all as in you cant hear a fan spinning then more then likely its your fuse... check your fuse box... there is a few things that can go wrong with the system and if its only putting out warmish air then you might just need to get it re-gassed.... check the fuse first though
    RKZ234 Guest
    It may also need re-gassing. There is a low pressure solenoid in the compressor which deactivates the fan.
    The system will not operate without the fan.
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    it's usually a leak in the system...it's a sealed component so it shouldn't stop working unless it is leaking.
    As ive been told.
