Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By detox_nath83
Thread: Vl auto kickdown does not work
    Vl belina
    Apr 2012
    Pakenham
    Default Vl auto kickdown does not work
    Hi guys, I just bought a vl Belina auto and it doesn't kickdown at all through any gears, can you pls help?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    drewVHSS's Avatar
    drewVHSS is online now Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    on my donor running gear i found a vacuum hose on the passenger side of the box had a split, may as well add vacuum leak to the above list
    Vl belina
    Apr 2012
    Pakenham
    Vl belina
    Apr 2012
    Pakenham
    well the hose thing on the swicth above the pedel that worked awesome thanks guys , now trying to get the fuel gauge to work ,it reads 1/4 tank sometimes but then will just drop, read a bit on these and need to know how to pull the dash apart to get the cluster out, any help
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vl executive 86
    Mar 2010
    Hey,
    My gearbox used to do this before I just got reconditioned. The mechanic I took it to wouldn't let me take it because part of the problem of no kick down because of the instrument cluster. That maybe something to look at but try all the stuff above first.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vb vn & vy
    Sep 2011
    Trafalgar Vic
    Quote Originally Posted by detox_nath83 View Post
    instrument cluster has nothing to do with kickdown.^^^^
    the speed sensor in the dash will affect the kickdown if its not working
    vb vn & vy
    Sep 2011
    Trafalgar Vic
    For the fuel guage problem, most instrument problems are due to dry solder joints on the circuit board. need to take the board out and resolder all the points, or at least the ones that look sus. If you cant find any thing here to help, try the calaisturbo site, they have a lot of info on this.
    Vl belina
    Apr 2012
    Pakenham
    Hi guys thank for all the info, I pulled the dash out and soldered the fuel gauge terminals an d now works a treat , so all problems (so far) have been fixed!
    Awesome site guys thanks
  1. Photoshop work, not auto!
    By AirStrike in forum Photoshop
    Last Post: 28-05-2011, 11:13 PM
  2. auto trans kickdown
    By vr-man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2009, 03:53 PM
  3. Auto Transmission Work
    By pyro_104 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 04:23 PM
  4. VS auto Slugish kickdown
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2005, 05:24 PM
  5. code 28 - slow auto kickdown fixed
    By rufion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 01:34 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
