Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Steering Wheel Removal
    sando_3000's Avatar
    sando_3000 is offline Prestige Panelbeater
    88 VL Berlina 5.0
    Feb 2005
    Brizzy
    Default Steering Wheel Removal
    Hey folks bought a new steering wheel n boss kit ,but cant get the old 1 off :b: , i had a look through the Vl Shop Manual , they say 2 use a special tool, where can i get this tool ? or can i Make 1 up some how ?, How did u'z get u'r wheels off ?
    Cheers, Sando.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Is it the original wheel? Undo the bolt thats holding it on. If its the original wheel, take off the pad and you'll see the bolt. Leave it on a few threads, Pull and wriggle as hard as you can. The special tool is just a steering wheel puller. Supercheap/ Autobarn etc.
    sando_3000's Avatar
    88 VL Berlina 5.0
    Feb 2005
    Brizzy
    Cheers Bextor , yeha its the original Wheel, i've tried wiggling n jiggling n pulling still no Sign of it coming free, it seems as tho taking that bolt hasn't helped at all even though it would have
    Dead Head Guest
    Leave a few threads on and when you are wriggling and pulling get your mate to tap the centre nut with a hammer lightly at first. And if that does not work then smash the shit out of it. (no go easy it will come off)
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Dead Head
    be carefull colapsable steering!
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VKnVLCalais Guest
    crouch down abit, get ur knees behind the bottom of the wheel at about 5 & 7 on the clock, grab the top of the wheel with left hand, hit the shaft with the nut still on it with a hammer and reef that bitch off. I did it 2 days ago to put my original momo brock wheel on my vk. too easy.
    sando_3000's Avatar
    88 VL Berlina 5.0
    Feb 2005
    Brizzy
    Thomo's Avatar
    Thomo is offline UNLEASH THE LION WITHIN
    FAMILY VT & HONDA 04 CRF250
    Aug 2005
    Goldcoast
    Mate all you need is a steering wheel puller about $20.Then all you is attach it to your wheel and screw the bolt with a spanner.NO HAMMERING NEEDED.
    Goodluck.
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    or you could save yourself $20 and do what it says earlier (leave nut on a little bit and bash), took me half an hour to change my stock busdriver wheel to my new one
    Going where no late model stato/caprice has gone before.... GAME ON!!
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    never ever hit it with a hammer. many cars have a sticker in the steering or in the book telling you that. it has collapsable steering and will move it. even a few mm can screw the horn connections, steering lock, and safety of the steering. my puller was under $15 from supercheap. well worth the money.
    remember not to hammer. its one of the biggest no nos, right up there with cutting your springs.....
    walesy's Avatar
    Jun 2005
    Perth SOR
    well i bashed my steering wheel and cut my springs... i dont follow rules
    '05 VZ Lumina 3.6V6
    Jun 2005
    Brizzy Baby!!! atm...
    Quote Originally Posted by vlv8vic
    agreed!!! man, dont know how to express how big of an issue thatcan be. do not hammer it at all! :b:
    Rollin Rollin Rollin
    macdee's Avatar
    macdee is offline your local "Hoon"
    VL
    Mar 2005
    melb, sth east
    i used a massive rubber mallet! and smashed the crap outta it!! trust me it works
    may contain traces of peanuts
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    and trust me, it could get someone killed. like cutting the springs. do it properly and safely or get someone who knows what they are doing to do it for you.
    last thing you want is your column becoming loose and locking up the steering because it was treated in a way it was not designed to be treated.
  15. #15
    Thomo's Avatar
    Aug 2005
    Goldcoast
    For the sake of $15 BUY the pully.Its cheaper then replacing the steering column if it collapses.
    cheers
  16. #16
    executive vt 5.0lt
    Feb 2005
    west suburbs
  17. #17
    stock_vl is offline wh internationals?
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    or you do it my way!! =) use your brain!
    i puller is a straight bit of metal with 2 holes in it exactly where theres to holes in the steering wheel!! see them??
    you get to bolts that fit in there and a peice of metal thats like 3" long then the metal goes across the main steering column bolt in the middle where u undo the 2 bolts with like a size 19 open ender.
    screw that plate in and it will easily take off the steering wheel no bashing no nothing! if u dont have the bolts there like $2 worth max and an old peice of steal!
    Last edited by stock_vl; 15-11-2005 at 07:11 PM. Reason: i said "yours your brain" cant spell.. retard.
    I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
  18. #18
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    mmm i dont have anything liek that lying around! cant store much junk when you move alot. granted though if you have scrap around and bolts and stuff.
  19. #19
    executive vt 5.0lt
    Feb 2005
    west suburbs
  20. #20
    VKnVLCalais Guest
  21. #21
    dan_man31's Avatar
    dan_man31 is offline now projecting oh yeah :D
    vl executive
    Feb 2005
    brisvegas
    oi buddy i got one of these puller's the dude who sold me the vk had one to pull the steering wheel off and he left it in the boot with a whole heap of spares i tried calling you but your phone was off sms me if u wanna try that ???????
    dan
    Its Stock And it Rocks .... ditch the bitch lets go racing
  22. #22
    Pistol Guest
    I think some steering wheels are harder to get off then others in the vl. I tried yanking mine off to begin with and it came off after a while. Then i realised supercheap had given me the wrong boss kit so i had to put the original back on to go into town and when i got back an came to pull it off yet again i couldnt cos it was fully stuck, i tightened up the bolts too much. went to the mechaincs round the corner and they had the removal tool, so all good in the end
  23. #23
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Quote Originally Posted by VKnVLCalais
    Rules are meant to be broken, GO THE HAMMER!!
    stop being a ****ing ******** mate. did you miss the part where a) thats really bad for the car, and b) it can cause the steering to colapse or lock which could get you or someone else killed? get off the roads pal.
  24. #24
    sando_3000's Avatar
    88 VL Berlina 5.0
    Feb 2005
    Brizzy
    Thanx 4 the ideas guys, bolloks 2 the hammer bashing i'll juz head over Dan's n use his wheel puller
    Cheers, Sando.
  25. #25
    executive vt 5.0lt
    Feb 2005
    west suburbs
    told you to use the puller
  1. removal of air bag steering wheel
    By iamsuperjeff in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2010, 02:49 PM
  2. removal of steering wheel
    By muzwoldian ss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2007, 02:21 PM
  3. Removal of VR Steering Wheel.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2006, 09:25 AM
  4. Steering Wheel Removal
    By ephect in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 09:00 PM
  5. steering wheel removal
    By junglepatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2005, 07:38 PM
