My VL came from the factory with a 308 engine number VJ577034 is this a SLR5000 engin?![]()
same kinda motor slr5000 is not the motor it is just a torano with a kit and a 308 5l
Weren't they 304s in the VLs?
just the normal V8.
and may i add, SLR5000 look sooo gooood with the dorp tank i saw a few today!
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
vl came out with a carby fed 304. if its an injected engine its a 308 unless its had a newer head and computer put in, but if you say its factory then forget about that bit!
All VL engines were 304's and all were carby, bar the Group A that was fuel injected.
AirStrike![]()
Selling FG G6E Turbo and buying a N/A Supra
and the VL Walkie's, they where fuel Injected too im spitty sure
your engine is simply the stock vl 304
http://www.oldholden.com/possible/in...ngine_Prefixes
if the engine number was prefixed by VW, then you'd have yourself an LV2 4.9 H/Comp. motor
Originally Posted by VN-SV-89-LE
Ummmmmm thats what I said right above you..............Originally Posted by AirStrike
AirStrike![]()
The VW prefix is for the A9L optioned engings as found in the Holden Group A (carby one). The LV2 option became the base model V8 in the VL, and uses the prefix VJ.Originally Posted by Mike215
AirStrike![]()
Wasn't there 2 Group A's in the VL... Brock Group A and the Walkinshaw ?Originally Posted by AirStrike
Brock was carby... Walky was EFI
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
Correct. Makes it difficult. There was the carby VL Group A's which were HDT/Holden made that were all permenant red, and then there is the HSV Group A (walky) which run port fuel injection.Originally Posted by sixshooter
AirStrike![]()
