need some vl computer fault codes please :
What i did was i went to my local library.They have car manuals there so it saves you $$$$$.You can photocopy the pages you need for around 20c a page.I know you can in qld but not shore anywhere else.Hope this helps.I have some codes i will have a look and see if i can find them and let you know.
cheers
VL FAULT CODES
Code 11 - Crank Angle Sensor circuit
Code 12 - Air flow Meter circuit
Code 13 - Coolant Temp Sensor circuit
Code 14 - Vehicle Speed Sensor circuit
Code 21 - Ignition Signal circuit
Code 23 - Trottle Switch circuit
Code 24 - Neutral Start Switch circuit
Code 31 - System Pass (OK) (Non A/C), A/C circuit (A/C models)
Code 32 - Starter Signal circuit
Code 34 - Knock Sensor cicuit (Turbo)
Code 44 - System Pass (OK) (A/C models)
