hey guys and girls, just wondering if a vl berlina cluster(with rpm tahco) will work in an executive eg. is all the wiring there for them to be a straight "plug in". because i have the clock but would like to put thee rpm tacho with the didgital clock....thanks 4 your help
yeah just plugs straight in real easy, except the oil gauge wont work properly, someone else might be able to shed some light on how to hook that up properly...
sully
As said, all works but the oil pressure gauge. You will need an oil pressure sender for the block and to change the wire in pin 14 (the blue one) to pin 2 on the black plug that goes into the back of the cluster and she'll work a treat...
yeah there is an article in the tech thread ill have a look later if i remember, the oil sender needs to be replaced, im planning on doing it myself
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
ok you beat me to it, i was just about to post it
thanx guyz...got it in now works great...didnt take me all that long either
nice, where did you get the cluster from
a wreckers in punchbowl...got there last one lol $40 works great
