Results 1 to 11 of 11
Thread: wiring tachometer
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Question wiring tachometer
    Hey guys and girls. when wiring in a tacho on a 6 cyl non turbo what do i connect the rpm signal wire to? on other cars with cylindrical coils it connects to the post where the wire runs off to the dizzy. what do i do as the vl has a sealed connector. Also the tacho has 6 wires. 2 wires i understand, 1 to headlamp source and the one for rpm signal, but the other for i'm not sure of. 2 for ground and 2 for power source. Do i need to hook both to ground and power or just one to each?
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    well im not too sure but, i think it plugs straight into the spedo, you could probabley find a write up somewhere if you search for it
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    Sep 2005
    vic
    there is one on calaisturbo
    http://www.calaisturbo.com.au/showthread.php?t=5854
    i really thinks just commodore should have a tech article section too, where only approved threads can be started
    my web site
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Sep 2005
    vic
    lol yeah i was pretty tired
    my web site
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    not sure why there is 6 wires.. but there should be one for ground.. one for power.. which u can hook up to the power of the dash.. one for the rpm signal which should also be on the back of the dash.. and one for the illumination.. hope this helps..
    I wonder what those scales on the top right side of my posts do...
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    What breed of tacho?
    They are normally.
    Green - RPM signal
    Red - power
    White - Power from dash light
    Black - Earth
    I am pretty sure the other wires are for changing to 4 or 8 cyl
    Jul 2005
    my bad.. doesnt hook up to the back of dash.. need to run it to the positive wire on the coil pack.. when the car is running.. get a wire tester n it should be pulsing on n off.. then u have to run it to inside the car.. this is definitley how to do it..
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i've told the signal wire, for the cars with the clock instrument cluster, is hanging near the alternator for those who wish to put in a tacho. now whether that wire needs to be hooked up to the coil and runs to the dash or if the wire connects to the tacho with the signal already running through it is another question.
    '97 VS Commodore + '98 E36
    Apr 2005
    naa mate..you dont hook it up to the postive terminal of the coil pack
    you gotta hook it up to the NEGATIVE TERMINAL, NEGATIVE!
LinkBacks (?)
  1. 11-09-2011, 06:42 PM
  2. 03-02-2011, 04:58 PM
  1. wiring
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 28-04-2007, 05:26 AM
  2. vr to vs wiring
    By john hartigan in forum Electrical Wiring / Questions
    Last Post: 14-03-2006, 07:04 PM
  3. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  4. wiring kit
    By garfa in forum Car Audio
    Last Post: 06-11-2005, 12:05 PM
  5. VDO tachometer
    By VNPOWER in forum Parts And Other Items For Sale
    Last Post: 07-08-2005, 05:19 PM
