just bought a 88 vl sl and was wondering what little things could i do to increase the hp?I want to slowly make my engine better and was wondering what i could do to it?Thanks (its already got xtractors on it and a 2.5 inch exhaust)
ok, well you want an xf throttle body and DEFENITALLY an XF throttle body
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
Please tell me more about XF trottle body and what is the advantage, and will it fit strait up to the original plennum. Is there a thread on this.
XF Throttle body is just increasing the amount of air that goes into the engine when you put your foot down. Instead of squeezing it through a small hole, its a larger hole and more can flow.
That kind of mod would combine best with your exhaust and then you could even get your inlet ported out etc. Depends how much you want to do. Get the breathing mods going. Stay external to the engine as much as you can unless you want to get into the big dollars.
cold air intake and filter. I heard xf throttle bodies were better for turbos guys?! Would he be better to just port his intake bit by bit.
search on www.calaisturbo.com tech article section for detailed info and a guide to do it, id look but yeah im feelin pretty lazy.
its a bigger throttle body so it gives better acceleration, and like bangers said. a cold air intake, cheap and works like a charm if you do it right K&N panel filter and you will be in business, shouldn't cost all that much either. btw just cut out the rear muffler and weld a pipe in place. but dont steal the tb off the blue XF down the back of pickapart on Canterbury road... thats mine lol
K&N filter.....
there not as illegal as pods and there actully rated at just as good! plus doesnt give the dud sucking sound! =)
run it on premium or put additives.
umm.... could possibly run a spark plug cleaner through it aswell and a couple of other things along those lines... as it may not be in PERFECT condition.
cold air intake.. meh i dunno anymore
I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
an 88 sl??
i thought they stopped making sl's in 86.
put in a cold air intake. theres defintelly threads on this.
Half a carton and still going!!! Now thats Economy
mines an 88 and it HAD a SL badge on the dash. I emphasise HAD. Now there is a HDT Sport badge there. I thought the SL and the exec were the same thing. Mine didn't have SL on the boot though. Dunno.....
they only started the vl in 86 did the sl run for only 1 year? cant haveOriginally Posted by VLACS
Going where no late model stato/caprice has gone before.... GAME ON!!
sl's were all the way through.
i thought so... whats the difference between the sl and exec?
Not much at all. Something to do with aircon/ powersteering/ manual gearbox.
Hardly anything though.
