Results 1 to 8 of 8
Thread: Aaaahhhhhh Help
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    Angry Aaaahhhhhh Help
    Ok guys having problem's just had the Holden mech fit my new water pump at my house yesterday.filled up with coolnat and bleed it this arvo thinking yay back on the road again.No for some reason the car sounds rough as hell and wont rev past 2 thou rpm im thinking maybe the mechanic hasnt done something right ot forgototen something.Im slightly woried now as i have no idea wot could cause this and it's pissing me off cos i wana drive my car :b:
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    first it should be up to the mech to fix for free (assuming it is something they left undone etc...) either way they should be able to troubleshoot for free.
    if you cant get back there soon enough though check over it yourself and see what you can see... if something isnt put back properly youll spot it.
    failing that start checking the usual suspects, water in electrics such as coil / dissy area, as well as the afm. it might have been bumped and it seems a ripe old age they are starting to fall to bits easy.
    goodluck mate.
    Dead Head Guest
    If you have cooked it when the pump went? keep your fingers crossed it is not the head. The mechanic would be a real dill not to pick it up, but just happened to me.
    CALAIS 6's Avatar
    Aug 2005
    dude i started the car on sat morning and the water pump died car was on for less than a second and then wasnt turned back on.The car never heated up at all pump just died when the car started.Had been running at a good temp uptil then too.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    CALAIS 6's Avatar
    Aug 2005
    He put new leads in it too so im thinking that he may of fecked up my firing oreder lol if he has ill go ghetto on that tit.Holdens finest lol
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Try reseting the computer, disconnect the battery for half an hour that resets the ecu, It could have picked up on the failed water pump and gone into some kind of protection mode.
    ========My Statesman 20's Mafless and 3.9's========
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    check the firing order.. on the lid of the dizzy it has the numbers next to where the leads come out.. wen i changed my engine mine had the same problem.. put it in correct order n drove like a dream..
    I wonder what those scales on the top right side of my posts do...
