Results 1 to 5 of 5
Thread: Lose auto stick
    2 BRUTAL Guest
    Default Lose auto stick
    Just been looking around a few VL auto's to use as a donor for my 4WD. looking at buying a complete car, but the few i've looked at, the auto stick has quite a bit of movement in the slide when it is in gear, if it's in drive you can move it about an inch or more either way, it doesn't jump into the next gear but it seems lose, is this normal and can it be adjusted or does it mean a very worn box. :b:
    Dead Head Guest
    Just at a guess i would say it would be in the linkages or the shifter itself, not sure if ajustable. What did it drive like?
    2 BRUTAL Guest
    The 1 I looked at on the weekend i couldn't drive it as it was half pulled apart, but it was quite loose, but the motor had a bad flat spot from idle and took a bit to get started so I left it where it was and will keep looking.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    im surprised you copped a 'few' with such movement in the shifter. My brothers was so tight we had to loosen it slightly. it is normally just in the linkage but could be in the box. either way youll get onto one with no apparent issues without any worries. they are all over the place.
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    where you at? when do you need one by? I'm getting rid of mine to put in a manual. I'll sell you mine. it's perfect. no problems with it at all.
  1. changing the button on an auto gear stick
    By disealx1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 06:12 PM
  2. how do u fix a loose auto stick?
    By crashy13 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2006, 10:40 AM
  3. Commodore auto gear stick help VX
    By tehMaz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 06:19 PM
  4. auto gear stick
    By bam bam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2005, 10:51 PM
  5. power button on the auto stick
    By dan_man31 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2005, 06:51 PM
