ive been thinking that when i change my engine while its pulled a part what are some cheap mods i can do while the engine is out?
like shave the head to the max
an if i put vs calais series 2 injectors in will it make much difference
an just little things like that will it make a noticeable change in the way it goes??
big bore throttle body dont know how much that is
cold air intake
extractors
2 1/2 exhaust
larger pistons need rebore for that one tho probbably cost heaps
depends what you call cheap and how far you intend to go
three thing in life are guaranteed
taxes
death
and car repairs
Get a decent cam and chip and the other stuff mentioned above. Don't shave the head, Just get it reco'd and clean the Injectors. With the money you spend you could have a stock turbo and it'll be quicker than your worked N/A. It cost huge $$$ to build a n/a into something worthwhile. Just a thought!
yea extractors and a 2.5 inch mandrel bent exhaust no cat an single straight thru muffler wer ment to of been going on this weekend but because i blew the motor up it was no go... and cold air intake is on its way
plus i have a ecotec motor sitting in the shed doing nothing i though if i could ill rip parts off that to put on mine
how much does cam an shit cost i dont wanna spend mega bucks because i give it a hiding an i doubt if the car will last me much longa i just thought if i could get bits off the ecotec that will make a difference that would be cool because it wont cost me ne thing
an i dont want any thing with mega hp because ill end up killing my self id just like some thing to do stompa burnouts
sounds like your a manic on the road dumpd6 haha. ill be sure to stear clear of you if i ever see you...
na you will be safe the f**king car spends more time off the road then it does on
a very expencive car the first time i had it on the road it cost $160 in rego an it was on the road for 3 days before it got defected
second time it was on the road got it off defect on the 3rd of last month rego $170 an it lasted untill the 29th before the bottom end went
Well ig uess they are there to be drivin, but to a certain extent, I believe that yea we have certain duty to these vehicles, to clean them out regulary, give em a flogging, but then there is TLC, and that is needed, big time, got to look after them, I feel you look after them theyll pay u back......
take care of the pride, so as to have joy, hence
PRIDE and JOY
Cheers HSV #8
Unfortunatly, the words " cheap ', and "mods " dont go well together. They are normaly not found in the same sentance too. Unless ur serious about the hunt for grunt, like compression, cam, or forced induction, all the other little bits and peices will be a waste of time.
Things like K&N, CAI etc, will help ur fuel economy and slightly improve ur throttle responce. It's going to take more than that to saticfy ur desires by the sounds of it!
Good Luck which ever way u go !!!
