Does anyone out there know of a site or program which you enter known data like, engine RPM, top gear ratio and tyre rim combo, so that it will tell you what diff ratio your car has.
A mate has an 3spd Auto VL Berlina V8. All appears factory except that it has had a shorter diff centre put in it by the previous owner.
The car does about 2850 RPM at 110 km/h on the Fwy, which is just nuts and is also why he only drives it at upto 80km/h or gets a lift!!!
We already know;
3rd gear is 1:1
Engine rpm is approx 2850 at 110 km/h
Tyre combo is 225 x 50 R16
By my rough mental calculations, I'm guessing it has a 3.45 centre.
The objective is to get as close as possible to 2000 RPM at 110km/h, as the car will be doing lots of Hwy k's once it is sorted out.
Any advice on the ratio fitted and/or directions to a website to do the calcualtions as well as the correct ratio to fit will be greatly appreciated.
From memory the V8's were all factory fitted with the 3.08 ratio but it might have been changed for a I6 or T6 ratio (3.45)
AirStrike![]()
Selling FG G6E Turbo and buying a N/A Supra
yup mines 3.08. sits on about 2700 (i think) at 100k's. Same 3 speed trimatic. drinks the juice for that reason.
it would be 1.08 for sure
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
these might help
http://members.westnet.com.au/scottl...gearratios.htm
cheers
Scott
a moroso power speed calculator is 10/15 dollars from any reputable speed shop it will calc power speed ratio tire et rpm mph weight shiftedOriginally Posted by RKZ234
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
Thanks for the replies people. He's decided to keep the 3 spd auto and go for a 2.6 diff, which aparrently will delver about 2100rpm at 100 km/h.
The cost of fitting a VS 4spd and tailshaft was just just too much for the boy.
