Results 1 to 7 of 7
Thread: VL headlight problems
    vl berlina wagon 6cyl
    Jul 2005
    Default VL headlight problems
    if your VL headlights are dull and new bulbs dont help theres probably lots of muck inside them
    Holden warns against touching the bulbs or using dirty gloves to hold them as this will eventually cause dullness, but I dont think this can account for the amount of muck often in them
    it helps to remove the front bumper top trim first, then remove the light unit and remove the glass front lens, it will usually be covered with muck on the inside, mine responded to mineral turps but keep this well away from the silvered part as it reacts with some worn areas, turning them dark brown
    the silvering is usually also covered in muck and worn away where it gets hottest and I dont know of any way to fix this, obviously the heat does the damage, the rubber that holds tha parking lamp is usually perished from heat and I couldnt find anything to replace it.
    The main 2 fillament globe is difficult to replace with the light unit on the car, a mirror helps to see whats happening, so leave the globes in untli its off the car.
    things were lots easier back in the days of replaceable sealed beam units
    replaceable VL genuine lights are still available and a cheaper non genuine unit is availab,e in melbourne from SSS auto, I have one and it seems OK
    I dont know if the callais lights are different
    VT SS S2 A4
    Aug 2005
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    not just holden but everyone reccomends not touching the globes. not only may it affect the view of the globe but the oil from your hands can get hot when the globe is on and cause it to smash the glass.
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    where can i get the inner silver plastic surround from cuz i decided to clean them out to make them shiny ready for blue vision, but the silver plastic in one headlight is burnt and very dullish looking.
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    try wreckers, might get some better ones. you can get them new somewhere... anyone?
    VT SS S2 A4
    Aug 2005
    evl Guest
    paint er up wif sum chrome paint mate. then chuck in sum ice blue bulbs an put sum coloured caps on ur parkies ull b krankin out the hotness... an who said it was hard to change bulbs. take ur battery out an ur airbox out (an leave the thing out) an grab the wee wire an use it like a gear stick. anyone(hopefully everyone)will know how to get second on a collumn change well its kinda the same.....lol
  1. VZ Headlight
    By Luke0011 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-01-2008, 09:32 AM
  2. vl Headlight Problems
    By anothercarnut in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-11-2007, 08:37 PM
  3. how much should i pay for a new VS headlight?
    By nickdanger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2007, 08:42 PM
  4. Headlight
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2005, 02:36 PM
  5. headlight
    By robcom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 08:13 PM
