Results 1 to 9 of 9
Thread: wheres the Coil Pack???
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    Exclamation wheres the Coil Pack???
    can someone please tell me where the coil pack is..? i need to find the positive wire from the coil pack.. but i've got no idea.. thx ppls...
    I wonder what those scales on the top right side of my posts do...
    Jul 2005
    somebody please??????
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    yeah buddy it is mounted to the front of your timing cover above your thermostat. follow the centre lead off your dizzy cap back. all the wiring is sealed though. i'm trying to find thr rpm signal wire myself to hook up a tacho. if you find it let me know.
    VL SL 5spd
    Dec 2005
    Quote Originally Posted by bangers
    To hook up an aftermarket tacho,
    - hook up the GREEN wire (that comes from the tacho) to the BROWN wire in the iginition coil.
    - Where's the iginition coil? in the picture below, do you see a round red plug above the fan cover? Well to the LEFT of that red plug, there is a black plug.
    - The lead to that black plug has three wires inside (you have to slice the outter black cover to reveal these wires); 2 is pink and 1 is the BROWN you're looking for!
    - The brown plug is negative, which is what you need to hook up the tacho.
    - Slice the brown wire to reveal the copper
    - Simply attach the green wire to this!. (you may need extra wire to reach)
    - Tape it all up nice and neat and your tacho should be working.
    Also, there is an short-cut method in hooking up the GREEN wire to the BROWN. Under the steering column, remove the cover, and you should see 2 pink & 1 brown. This is identical to the pinks & brown from the iginition coil.
    ALSO I haven't mentioned about hooking up the red (power), black (ground), white (lights) wires that came with your tacho, which you should be able to do quite easily under the dash.
    Attached Thumbnails Attached Thumbnails wheres the Coil Pack???-wreckmotor.jpg
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow The pic
    Hi I was just looking at your pic and see there is 2 cables going to the throttle body, is 1 for your cruise control??
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL SL 5spd
    Dec 2005
    Possibly, but I'm not sure as that pic isn't my car. My car doesn't have cruise control (SL 5spd).
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    thanx for the help buddy. no one could tell me for ages how to find the signal wire. my hat's off to you.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    thats also a good spot 2 wire up a kill switch, ive done mine there and its workd wonders, stopd the thiefs in there traks
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Oct 2005
    for a shift light how do u wire that in, coz i want 2 hook 1 up 2 my dash and mount it on the steering colum?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. Coil Pack
    By Willow01 in forum Electrical Wiring / Questions
    Last Post: 06-12-2008, 08:37 PM
  2. VS coil pack
    By mark_1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 06:29 PM
  3. vn coil pack
    By underthepump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2006, 05:11 PM
  4. Coil pack
    By Terfade in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2005, 09:40 AM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
