Results 1 to 16 of 16
Thread: Losing Power
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    Unhappy Losing Power
    hey ppls..
    i got a bit of a problem..
    it seems that my gears are all smaller, and when im driving at around 80 + k's
    if i put my foot down.. the injection doesnt kick in n it goes really sluggy?!?!
    ANY IDEAS?
    talkin to some ppl they seem to think the injectors are stuffed (not the fuel injection) but i dont see how this can happen overnight..
    any ideas? I NEED POWER!
    I wonder what those scales on the top right side of my posts do...
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    take the injectors out and out them into a tub of metho and plug them up to a 9v battery for 10 minutes, rthat will clean em nice
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    what are the injectors that arent the fuel injection injectors?
    could be your gearbox, low on fluid, or overful.....
    Jul 2005
    apparently its the fuel filter thats clogged or sumfin... so im gonna get a new one.. rekon it'l fix it?
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    sounds like a good start at least.
    im still confused about the "injection not kicking in" theory, "but not the fuel injection"...
    can you help me out here?
    Jul 2005
    hmmm... not too sure i confused my self too.. sry..
    does anyone know how to change the fuel filter? need some help coz i jus bought one..
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Stewart1000
    lol You got that from what I say, no need for 10mins though man. sheesh a lil overkill......... 1min if that each injector.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Jul 2005
    Does anyone know where the fuel filter is and hot to change it?
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Drivers side wheel arch.. If you jack up the car, support it with a stand and slide under you can see it. Follow the fuel lines from the rear passenger door, Underneath.. if you reach under with your hand you can feel the lines even.
    What you need to do is start the car and remove the fuel pump relay and let the car die. Try and start it again with the fuse out and then if it doesn't start your right to go..
    Undo the two clamps holding the current filter on. Work quick and have a towel on you ready for spills. remove the old filter, put the new one in, making sure direction is the right way.. Then do up the clamps.. Put the fuse back in. Turn ignition off/on a couple of times- Start the car, check for leaks. Done.
    Edit, as for the injection switch or whatever, maybe just thinking about the kickdown switch at the back of the accelerator pedal not getting a good enough connection and kicking back that gear fast enough.
    Is that all you mean by losing power or is there more to the story.
    Jul 2005
    all my gears change quicker then before, n afta 80k'z if i put my foot down.. it doesnt kick in it jus goes really sluggy n the speed rises really really slowly... its like im not putting my foot down at all..
    do i need to do all that stuff to change the filter? cant i jus change it?
    Bax
    Nothing
    Jan 2004
    QLD
    Thats the method all the repair manuals describe. It's really not much there, would take about 10 minutes. All your doing by removing the fuse is depressurising the fuel system so when you take the hose off it doesn't go everywhere and you don't lose as much fuel.
    2 minutes preperation that will save you 10 minutes cleaning up.
    Jul 2005
    k all is done n all went well.. my problem is mostly fixed.. jus a quickie....
    my gear ratios are all weird now.. when i put my foot down it goes hard once again.. but gear ratios are shorter.. should i reset the computer to fix this?
    Bax
    Nothing
    Jan 2004
    QLD
    Can give it a go I guess. Battery off, pump the brake a few times, then drive it hard from the get go.
    Still don't know whats going on, your ratios shouldn't change
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    could also be your gearbox...r u talking about the power kickdown, i have a prob with my car occasionally, driving at 80k's got to the straight down went the foot up went the speed not sluggish at all, but yesterday foot goes down speed goes up SLOWLY.
    getting my gearbox serviced maybe check out my button on the peddle cuz its a bit shit when you trying to overtake but it just don't make it... don't really like chucking it back into second at 100.
  15. #15
    Jul 2005
    yer i let a mechanic drive my car today n he seems to think my trans needs a service... so should be good.. anyone know the price on that?!?
  16. #16
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    $70 to $150 dependant on where you end up getting it done.
    like bex said, gear ratios dont change, it might just seem that way because it isnt kicking back like it used to. I got a new box and had to get used to it kicking at different revs.
  1. my V6 is losing power.Help !!
    By custom vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 11:01 AM
  2. Losing Power
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 12:58 PM
  3. VR losing some power, starting off
    By Radar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2006, 03:34 PM
  4. VL missfire losing power
    By STYALR in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2006, 06:56 PM
  5. Losing Power But Not Like The Other Post
    By vlturbo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-11-2003, 06:36 PM
