Results 1 to 7 of 7
Thread: Buying a VL - What to look for?
    EF Almost Turbo
    Jun 2005
    Default Buying a VL - What to look for?
    What negatives should I look for? Ie, rust locations, general problems etc..
    I'm hoping to get a VL Calais..
    Thanks
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    vl berlina wagon 6cyl
    Jul 2005
    check all the usual things, rust generally isnt much of a problem but I dont know how you are supposed to check for rust on the floor as removing or lifting the carpets isnt easy
    especially check for rust around the windscreen or poorly done rust repairs there , use a magnet
    look for signs of water leaks under the dashboard
    if its a 6, the engine should be very smooth
    VRFURY's Avatar
    VRFURY is offline Just Nic
    VR Caprice
    Jun 2005
    Warragul
    so true, but i got all my rust cut out properly and to save money i touched up the paint my self so mine looks a bit cheap but the rust as been cut out properly, it cost me $750
    Behind every Great chick, Is a guy checkin' her out
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    4 rust peritions look under the boot ruber seal if u can as that whole lip is commen 4 rusting away and the bottom of the parcel (aove the seat belt houseing) is a main rust area,
    check the reaseat belts retract fine because if the window has a bad seal (rusted though at the bottom of the window) the water gets in runs down the pacel shelf (causes rust on this 2) and runs off into the coil of the seat belt houseing causeing it 2 seze and stop retracting, xpenvie 2 fix coz its ilegal 4 wrekers 2 sell them 2 u, BUT a carton off beers will fix that problem and they cant give u a recepit
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    EF Almost Turbo
    Jun 2005
    OK, I bought the VL.. it needs a respray, but has 9 months reg, and is mech A1..
    Personally, I think I did alright.. paid $1500
    Thanks for tips, i looked for rust and there was a TINY bit so i let it slide.. (the rust lookout)..
    DaZ
    The_Monk says:
    im a leech
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    was that a calais? sounds very nice
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    EF Almost Turbo
    Jun 2005
    No, not a calais..
    DaZ
    The_Monk says:
    im a leech
  1. Buying a SV6
    By cladiges in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2007, 04:53 AM
  2. When buying a vz
    By knight97 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2007, 05:13 PM
  3. What to look out for when buying a vr
    By VKStevo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 11:19 PM
  4. Buying a VT SS 5.7
    By patullose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 10:37 PM
  5. maybe buying a vs on gas - what to look for
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2005, 06:11 PM
