Results 1 to 9 of 9
Thread: remember the fan clutch
    vl berlina wagon 6cyl
    Jul 2005
    Default remember the fan clutch
    Defective fan clutches are a common and often overlooked cause of overheating. The shear characteristics of the clutch fluid gradually deteriorates over time, with an average loss in drive efficiency of about 200 r.p.m. per year. Eventually, slippage reaches the point where effective cooling is no longer possible and overheating results. (On average, the life of a fan clutch is about the same as a water pump. If one needs to be replaced, the other usually does too.)
    If the fan clutch shows signs of fluid leakage (oily streaks radiating outward from the hub of the clutch), spins freely with little or no resistance when the engine is off, or wobbles when the fan is pushed in or out, it needs to be replaced
    a faulty fan clutch may cause air cond problems too, by allowing the compressor to overheat and be turned off automatically, due to not enough air being drawn thru the air cond radiator
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    VP EXECUTIVE 3.8 V6 t700
    Jan 2005
    Armadale Perth
    Smile thermal stock fans
    tossed mine put in a thermo out of a mazda, been fine since
    VT SS S2 A4
    Aug 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Hmmmm very interesting I have 2 spares so I might change it over. Are there any telltale signs of a worn clutch fan?
    ========My Statesman 20's Mafless and 3.9's========
    Jul 2005
    there will be noticibly less air being blown back if its not working properly, someone suggested poking a rolled up newspaper in the blades, a working clutch should cause the paper to be cut, if the fan stops, the clutch has had it
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    can also work the other way, the clutch is there so the engine can rev up quicker without the fan spinning at the same rate, the clutch allows it to catch up with time.
    You should be able to turn the fan with your hand (engine off!) without too much effort, but should not be able to free spin it.
    sometime when you shut the engine down they might give a bit of a turn, only because they get warm and the fluid becomes less viscious. (sp?)
    on the other hand, if they wont turn, or take alot of effort to turn with your hand then they are probably screwed as well. another tell-tale sign is fluid leaking from the fans clutch.
    when mine died there was an almighty roar as i accelerated, the fan was spinning at the same rate the engine was revving because the clutch had lost its bearings, then fluid, then seized up.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default electric fans
    There are brilliant thermo fans on the market and theres some that couldn't blow enough air to cool even in a gale wind....
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jun 2005
    South OZ Adelaide
    Default Harry
    The only way to check a clutch fan is to spin the fan (Engine off and Hot) mark a blade with tape or , give it spin by hand and it must not spin more than 1 an half turns!!! thats it, and as the clutch has a thermal spring in the middle it senses heat and adjusts to suit conditions....
    If anyone's interested there's a thing you can do to feel and hear it working....
  1. Anyone Remember These?!?!?
    By HoZy in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-02-2007, 05:29 PM
  2. remember me
    By commod8 in forum Site Feedback / Site Problems
    Last Post: 14-03-2006, 01:17 PM
  3. Remember Me
    By Torana in forum Site Feedback / Site Problems
    Last Post: 24-07-2005, 11:51 PM
  4. remember these??
    By rattattack1313 in forum Jokes/Humour
    Last Post: 25-04-2005, 12:08 PM
