Im kinda ummin and arrring about my exhaust...taking it in 2moro morning...just recently took it in to another exhaust shop to get the cat replaced...took it to another joint 2day and my muffler(i believe) is stuffed aswell(the oval cylinder thing) He said he was gonna "do me a favour" and drop it back to a 2 1/4 (from 2 1/2) exhaust with straight through muffler, and keep the hotdog and tip, and bend it up a little more so its not vibrating on my axel...said it will give more power and better fuel econemy, he also said something bout keeping the cops off my tail by doin this, but i don't want the sound to completely change into something that sounds like a pussy. (i like the sound its putting out, rummbling on idle)
What are the key things in exhaust that make the sound/note (would a quarter of an inch change the sound alot?) and wat would everybody else do??? Cheers![]()
yeah it will change alot but will probabley give more power. the boys over on calaisturbo always say it will. you could always take out the hotdog
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
what does taking out the hotdog do? What is it's purpose.Originally Posted by Stewart1000
hotdogs or resinators replace the muffler on the rear it cause the car 2 sound deeper but its less efective (loss of power), where a quiter car is more effective (meh) because the exhaust is set up right
my opinion the beta it sounds the beta it gos
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
well i don't want it to be quiet. Hence the reason i asked if 1/4 of an inch would make a big sound difference.
o ### yer, it would sound like a daewoo!!! if ur happy with the sound keep with wat size u got regardless wat the dude says.
its up 2 u, its ur car and ur money
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
well i got it done, only got the muffler replaced....It sounds the same at idle which i wanted, but when the foot goes down it makes that loud hollow noise, which aint too bad. It goes from 2 1/2 down to a 2 1/4 straight through muffler back to 2 1/2 exhaust, hotdog and tip.
yeah it shouldn't make much of a sound difference with the 1/4 inch difference. so did you get your rear muffler replaced with a hotdog? the rear muffler is the resonator if i'm not mistaken, and is ok to remove (will sound good), but the middle muffler if removed will create a tinny note.
Extractors to cat to 2 1/2 pipe to 2 1/4 straight through muffler to 2 1/2 pipe to hotdog to tip
