Results 1 to 12 of 12
Thread: hmmmm mini spool
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default hmmmm mini spool
    i was thinking bout a mini spool in my vl,
    ive heard its fun but is it possible to drive normally eg turn a turn and not have the wheel on the inside screach?
    and i was thinking bout a LSD would that be bout the same price as a mini 2 get fitted or is it big bucks?
    coz i was reading a lsd with 200lb spring in the housing is as fun as a mini spool but is legal and is able 2 turn turns safely
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    If You Want To Do doughnuts Then Dont Get Lsd. Do Doughnuts With Lsd And They Go Bang. Mini Spools Are The Way To Go For Burnouts But They Are Completely Locked At All Times, Yes You Will Get Chirping When Turning Sharp And Will Be Crazy Turning Corners In The Wet! Best Thing Is To Get An Lsd Built Tight And Do Burnouts But Not Doughnuts. not unless you want to fork out for a detroit locker......
    Oct 2005
    so would a mini spool churp if u took a turn at a sensible speed? or if u were stopd at a turn the you turn? not flating it or flooring it but safly taking off in no hurry eg: in fuel saving mode?
    would it churp then?
    and anther thing would u just recomend biting the bullet and saving 4 a LSD bout 600 fittd the get it built or just getn a mini spool 250 (my prefrance)
    im not the type 2 flaten it at every turn, im more mature then ur avg P plater (think) and ive heard nothing but LSD stuffn up time after time, and mini spools just keep on going and going and going and BANG tires blow
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    VT
    Apr 2005
    QLD
    as blown said, depends what you want to do with your car that should dictate your choice. a mini spool can be had for real cheap and saying that, they will last you if you drive sensibly. have some mechanical sympathy in other words. a properly set up lsd will give you a good service life too, it's just a sad fact that the holden lsd is let down by its tension springs that weaken over time.....go the spool.
    Oct 2005
    k cheers,
    has anybody had or have a mini spool in the vl because i want 2 now if it real is notacable? compared 2 stock diff (open wheeler)
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    VS COMMODORE
    Aug 2005
    my m8s bro has one in a vr n it is noticable when you turn slowly and it also increases the turning circle of the car and the car will want to go straight all the time. mini spools cost like $100 and could prob be put in for like $60 which is a hrs work if it would take that long. but it is ilegal to have fitted and will void insurance if they find out. aparantly a kazz is fair good but they are also fair pricey
    Sep 2005
    Id Still Go Lsd. Too Dangerous On The Road With Mini Spool, L8N is right, all they want to do is understeer. Plus Its Just Gonna Strain Your Whole Drive Train.
    VS executive
    Jan 2005
    so lsd wont break easily if there well put together. if you drove psycho in with a well put together lsd and another psycho in a minispool. which would last longer?
    Half a carton and still going!!! Now thats Economy
    VT
    Apr 2005
    QLD
    Quote Originally Posted by VLACS
    i think the tyres would be first to go......really, it's hard to say, what sort of lsd is it? a standard issue holden limited slip? if so, i think the mini spool would last longer.
    VS COMMODORE
    Aug 2005
    VT
    Apr 2005
    QLD
    Quote Originally Posted by L8N
    a kazz is a lsd isnt it they r strong as aparently
    yes, they are a form of pure mechanical lsd and they are an awesome bit of gear. they are a bit exxy though, but i presumed we were only talking about the holden lsd vs. spools.
    silvervl Guest
    I was replacing axles with a mini spool till i bit the bullet and got an lsd had no probs since. And i can drive through an underground carpark without making people cover their ears.lol.
  1. mini spool
    By kizza231188 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-12-2009, 05:43 PM
  2. mini spool
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-05-2007, 05:28 PM
  3. Spool/Mini-Spool VS LSD
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 08:14 PM
  4. mini spool in vn v6
    By 4eyedperson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2006, 08:58 PM
  5. WTB: mini spool
    By charged vp in forum Swap / Wanted to Buy / Trade
    Last Post: 27-03-2006, 08:51 PM
