Results 1 to 10 of 10
Thread: Engine swap?
    Piccolo Guest
    Default Engine swap?
    Wanting to know if its possible to take a VL holden RB30 engine and put it in an 86 Skyline??
    Wondering if the wiring harness and the computer system are the same??
    As in, does everything plug in the same or do modifications have to be made to accommodate the holden engine?
    Any information would be appreciated!
    Thanks.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    hmmmm
    think there is no point in doing that coz there the same engine, and if u mean like the whole set up eg turbo and plumbing there would b no point because the engine bay is differant dimentions so it wouldnt fit,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Piccolo Guest
    Default thanks....one more thing...
    thanks for the reply, would you be able to give me more information?
    i have a friend who has a standard VL, he wants to sell it cheap and i have a skyline with a blown engine so i was wondering if i buy the VL and take the engine out of that, and put it into the skyline??
    there are no turbo's or anything on it, both are standard.
    reason i'm interested is because the VL is worth $200 and the nissan RB30's are worth $330 so im looking to get the VL as an alternative?
    Oct 2005
    i cant c y not it wouldnt work,
    but the vl engine had the head (think) shortnd because the engine wouldnt fit under the bonnet, this shouldnt affect it,
    why not just keep the vl complete, its proberly quicker then the skyline because its liter by 200kgs
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Piccolo Guest
    Default thanks
    thanks very much for the information mate, cheers for getting back to me so quickly....
    im optimistic now, im just a little worried about the wiring harness for the VL because i've heard otherwise....any thoughts??
    liked the comment about the VL being quicker, but i have to say im a skyline fan....
    Oct 2005
    hmmm the loom im not sure about, try Skylines Australia. They are RB specialists there
    could get a electrion 2 fix it if it dosnt work, add me 2 ur msn (vl_berlina_5speed@hotmail.com) and ill give u a pic of my engine bay so u can try and match it if u want (very despret)
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Piccolo Guest
    Default Thanks Heaps
    Cheers for the info thats great, ill try skylines australia
    i'll add you to my list, and thanks again
    seeya
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    What's wrong with the vl that would make u want to swap the engine over? All the extra work to put engine into a box(shape) skyline...im a fan of skylines myself but id definitly ride in the vl over the r31 anyday. Round 3 years difference in age and valued the same? All up to you though.
    The engines are the same including the head...they just have a different set up under the bonnet...skyline engine bays look so empty compared to the vl, just you might want to check you mates vl head...if not looked after properly it could be cracked which means dollars to fix...just making that asumption because it so cheap even if he is your mate.
    Piccolo Guest
    Default thanks
    thanks for the info, unfortunately the rest of the VL is a write-off... so the engines worth it for my skyline.
    plus the VL engine revvs to 7500 whereas the skyline only revvs to 6000...
    thanks again
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    The AFM has a different plug and its a different type of AFM as well so I'm thinking all the wiring may be different. The engines are identical except for on the VL the intake setup is mounted lower to clear the shorter bonnet.
    ========My Statesman 20's Mafless and 3.9's========
  1. engine swap?
    By jazzawithvg38 in forum Straight 6 Development And Modification
    Last Post: 15-11-2007, 07:10 PM
  2. LS2 engine swap
    By leonthalion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2007, 05:11 PM
  3. engine swap
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 10:26 PM
  4. engine swap (vk to ??)
    By phat_com in forum Just Commodores Polls
    Last Post: 26-06-2006, 09:28 AM
  5. Engine Swap
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 07:16 AM
