Results 1 to 16 of 16
Thread: vt brakes on2 vl
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default vt brakes on2 vl
    my old man might b getn rid of his vt brakes on his vs and i was wondering if they would fit on the front of my vl?
    would anything be needed like a hub adapor, new bigger lines, 1" master, booster, slave or should it fit str8 on and use the curnt set up
    parts ive got:
    vt discs
    twins spot calipers
    lines (think)
    parts need?
    plz help me with this part
    cheers sean
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Oct 2005
    anybody have the slightest qlue?
    coz if i dont find out they proberly b sold 2 my dads mate
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    EF Almost Turbo
    Jun 2005
    take the entire braking system to be sure mate, and consult a workshop manual to confirm the current setup.
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    Oct 2005
    well he hasnt got the vt booster and master cylinder, thus the reason he down grading bak 2 stock (on the vs)
    so i wouldnt even be able 2 run those calipers on my currnt booster (stock vl system)?
    my disc ar starting to hit the end of life time so i was hopen it would b a str8 swap, no other changes
    and if a booster isnt bigg enuf wats symptoms dose it cause?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    It will not have enough pressure to clamp the 2 spot calipers if the master cylinder and booster are not up to the job, you will need the hubs and correct brake lines. I think you can get away with a v8 or turbo master cylinder and booster(not 100% sure).
    ========My Statesman 20's Mafless and 3.9's========
    Oct 2005
    the brakes r fianlly off vs, looks like a str8 bolt on 2 the vl. all the same layout and pattern.
    i read up on the vls master cylinder and it says its bore is 23.8mm, would that 1.2mm differance from the 1" really make a major diffrance in the feel and performace of the breaking?
    ucwepn cheers 4 the info
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I assume it would work but you wont get the full potential of the twin pistons.
    Oct 2005
    o well looks like it going to have 2b trial and error
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    make sure you change the hubs over. you need a 1" master cylinder to get the brakes to activate fully.especially in emergency.
    Oct 2005
    Quote Originally Posted by bangers
    hubs? wat r these and wat will these gain or succsed? r that just the part which hold the studs on
    and im proberly going 2 run the stock master cylinder 4 the time being till a VLturbo 1 drops ner me when i have money
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    on the front the hub slides onto your stub axle and houses the bearings. it secures the rotor (brake disc) in place. you need the vt hub to secure the vt rotors.
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah they should bold on, there are kits to put the VT breaks onto a vl so have a look at one of them and see what you are missing and try and get that part seperate
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    Oct 2005
    havn problems finding 1 of these kits
    i was look at my discs and my stock 1s have a differant lip on it compard to the vt discs. would this affect it? eg wheel fittn on
    and the vts brakes (which was on a vs) were held on by any thing just the caliper held it in place and the studs. i was thinking would this b ok on a vl if the hubs dont need swapn and it fits ok?
    the calipers line up ok with the mount its just the little disc problem i wanna c if i can get a insite on, b4 i try 2morrow
    im currntly broke so im hopnn its a str8 swap
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Sep 2005
    vic
    try and see if your wheels fit onto the vs while the vt breaks are on it
    search on ebay for somethign like "vl vt breaks" with out quotes
    my web site
  15. #15
    Oct 2005
    :my: 250 bucks 4 a pair off hubs, hope i deffantly dont need em
    http://cgi.ebay.com.au/HOLDEN-HUBS-T...QQcmdZViewItem
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  16. #16
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    You need the adaptors, they are available through the shop on jc's.
    1" master would be recommended to give you a stiffer pedal feel. Same with the Booster, I've been told by alot of people its needed, but you'll get away without it. Especially when the cost of a new one is a bit steep.
    Talk to Garth or Darren, in the shop all the information for these conversions are there, you may be able to get a seperate piece or two.
  1. VZ HSV brakes
    By GROWLZ in forum General Discussion
    Last Post: 17-11-2009, 04:32 PM
  2. brakes help!!!!!!!!!!!
    By vn_lexcen_s2 in forum General
    Last Post: 06-09-2006, 12:24 AM
  3. Brakes
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 09:55 AM
  4. VK brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2006, 08:01 PM
  5. Brakes
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:45 PM
