Results 1 to 9 of 9
Thread: Timing
    vl executive
    Jan 2006
    Default Timing
    hi i have just replaced my water pump and i took the timing tensioner off and havent touched anything yet so dose that mean if i just put the belt back on it will still be ok not out of time ( i havent turned the motor over )
    thanks
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    did you put your engine to TDC? the belt has a white mark on it. put the belt on with the mark in the exact same spot as it came off. you really should replace the belt now for a measly few quid instead of having to replace it later on and have to pull it all apart again.
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah replace the belt whiel its off, it would probabley need replacing anyway
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    vl executive
    Jan 2006
    kool thanks i dont know i wasent taking notice of the tdc or positions of the piston but my mate has a timing light he can help me and i will replace the belt thanks guys ( isnt the water pump a bitch ) basically have to take the frount appart
    Sep 2005
    vic
    yeah, im gonna be doing it soon, i wanna put on a PWR electric water pump, keep it flowing all the time
    my web site
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by Stewart1000
    your water pump is running all the time anyway. it's just the thermostat prevents the water going through the radiator until it warms up. what happens if the electric pump dies or has a short. all of a sudden your temp will hit boil. safer to keep original type of pump.
    VL Calais
    Dec 2005
    Did you take notice of where the spring sits? Mine was incorrectly assembled, and it was too loose, just replaced cambelt but Im not sure ive got the spring in the right place now, might be too tight. Where does the leg of the spring rest- i put it against a stud sticking out of the block that seems to be there for no other reason?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it looks wrong but it is right against the silly little stud at the bottom of the tensioner
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i did mine a few years ago did not take much notice about tensioner still going ok
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. cam timing
    By aghatas in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2006, 08:30 PM
  3. vs v8 timing help!
    By mean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:52 PM
  4. timing
    By vn series 1 owner in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 07:50 PM
  5. VL Cam Timing
    By vetteman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-06-2006, 07:48 PM
