Results 1 to 7 of 7
Thread: some tests?
    Steve-0 Guest
    Default some tests?
    just wondering if there are any tests that you can do ya self on the O2 sensor, CAS and AFM to see which one (if any) are making my car run rich? i havent got enough cash for a mechanic at the moment
    cheers
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Its probably just the o2 sensor or the coolant temp sensor. (the yellow plug on the top radiator hose at the engine) If the coolant temp sensor is dirty or corroded it will tell the ecu that the engine is always cold and to run a rich mixture, take it off and give it a good scraping. How do you know that its running rich may I ask?
    If its just excessive fuel consumption its prolly the o2 sensor, but if there are clouds of black smoke when you boot it its running rich and is prolly the coolant temp sensor
    ========My Statesman 20's Mafless and 3.9's========
    vl & vr commodore
    Oct 2005
    adelaide
    can someone tell me where i'd find the 02 sensor and are you sure the coolant temp sensor is the "yellow" plug , i thought it was the small slide on clip next to the yellow plug.
    Steve-0 Guest
    using alot more fuel than normal, a little bit of soot crap on the bumper
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    according to the gregory's manual its the yellow plug not the sliding black one for the coolant temp sensor. O2 sensor is on the exhaust manifold
    VS executive
    Jan 2005
    Quote Originally Posted by Steve-0
    oh man. im using way to much fuel then. i got mental black shit
    Half a carton and still going!!! Now thats Economy
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    take the plugs off the o2 sensors, get a multimeter and probe the black wire and the purple wire on each 02 sensor. it should be fluctuating between 0.0 and about 0.7 volts when warmed up revving at about 2000rpm, so its gonna be some hot work unless you can find the wire that goes into the ecu. Id go and look at mine but its in the workshop at the moment. best to do it under the car jacked up with somebody keeping the revs up about 2000 rpm. the voltage should fluctuate a couple of times per second from 0.0 to 0.70. if one or both are sitting at around 0.7 they are either buggered or the earth is no good to them. you will probably find one is buggered and one bank of the engine is running in open loop mode and the other in closed.
  1. diagnostic tests holden or home
    By vincent49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2008, 08:33 PM
  2. Drug tests
    By minux in forum The Pub
    Last Post: 28-02-2008, 04:04 PM
  3. drug tests on the road
    By VL-187 in forum The Pub
    Last Post: 23-01-2007, 04:36 PM
  4. Why do VP's seem to go faster than the VR's according to the magazine road tests?
    By muso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2006, 01:53 AM
  5. Vacuum Tests
    By richie83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 10:28 PM
