Results 1 to 14 of 14
Thread: Engine Conversion How Much $$$$$$$$
    Cherrys Guest
    Exclamation Engine Conversion How Much $$$$$$$$
    ey guys
    i have got a half smick Red vl sl with a slightly modified RB30 under ta hood, i am thinking of getting a half-cut skyline which is worth $5500 its a RB26DETT Manual, what sort of $$$$$$$$ am i talking to get tis thing fitted and running a rough estimated would be very grateful or any imformation about this engine conversion would be helpful to me
    tankz guys
    :b:
    VT SS S2 A4
    Aug 2005
    Cherrys Guest
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    why would the cost be soo high for the rb26dett
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    But he said he could get the rb26dett halfcut for $5500 so around $2000 for the conversion and around $2000 on big brakes and engineering. so all up $9500 that is quite a good deal if you ask me.
    ========My Statesman 20's Mafless and 3.9's========
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    by the way you will need an engineers certificate if you go from non turbo to turbo, or even just from standard engine to non standard (engine transplant). The engineer will check things such as adequate braking power,structurally sound installation, and safeness of the vehicle. Once you get the engineers certificate you can then get it re-registered.
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    How much power does the rb26dett have?
    Why not buy a cheap manual VL Turbo (far less than $5500), rebuild the motor, and get the turbo sorted properly. You'd have heaps of change left from $10000 + what you could sell the non turbo car for. Set it up right and the puny 150kw standard output (puny for a 3.0litre turbo motor) can rise by up to 50% (225KW) with a few simple mods. The standard turbo runs very low boost and it is not because the motor can't take more. The motor was setup to be auto box friendly.
    Just a thought as I know nothing of the rb26dett other than I'm guessing it is 2.6litres and twin turbo which means it could put out as much as 206Kw or as little as 166Kw.
    I may need to be shot for my ignorance though. So feel free to show me the light.
    Boonz's Avatar
    Jul 2005
    Quote Originally Posted by ucwepn
    $2000 for engineering.........i wish! the engineering and labour costs for this would be huge.....and i mean huge
    VP Executive R-spec
    Jan 2005
    Engineer certificates in Victoria are around $600 right? what's this $2000 story if they charged that much no one would bother and just drive around illegally, no goverment with a brain would let that happen Oh yeah in the rules for Victoria I noticed ther eis mention of turbochargers in the rules that say what needs to be looked at by an engineer but there is no mention of superchargers, that makes them legal as far as I can see (so long as you aren't making much more power than stock)
    Boonz's Avatar
    Jul 2005
    i meant it will be over $2000 for engineering AND labour costs from other people that will need to help on the conversion
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    The engineers certificate itself is only around $700 and to fit big brakes will be around $1300 + $2000 labour for the transplant at least so around $10,000 all up is pretty close to what it will cost including the halfcut for $5500.
    The rb26dett comes out with standard 206kw (according to the gentlmans agreement) but with a few mods (around $10k) you will have an easy 500hp or 380kw. ATF
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Thanks for the figures ucwepn.
    I have heard that the 206Kw limit is to be or has been withdrawn. I have also heard that many of the jap performance motors (especially Nissans) are actually way over 206kw mark. When you see the performance figures for some of these cars there is no possible way they are only putting out 206kw. Cars of similar weights, showing more power and torque and similar gearing, get no way near some of them.
    If I remember correctly, the first Nissan Skyline Turbo (Godzilla- $130000) released here was listed as having 206KW but put out closer to 310kw when tested.
    If this is the same motor and you have the money it would make a very interesting car indeed as VLs weigh less than the original Skyline which when perfomance tested laid 12.9 second 400m times straight out of the box (I think, sorry I'm getting old). What sort of gearbox would you need though?
    I am dreaming of my yet to occur Lotto win now so I'll stop planning a sleeper I can't afford and babbling on.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    yeah it will be pricey and my estimation of cost could fall short of the final figure. You will definately need a vl turbo diff or a 9 inch to cope with the power, and for a gearbox if the halfcut comes with the six speed manual use it and get a heavy duty clutch.
  1. vr 304 engine conversion
    By 308commodore in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-10-2007, 06:14 PM
  2. vs-vy engine conversion in a vp
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2007, 01:18 AM
  3. engine conversion
    By holdenmum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2007, 08:00 AM
  4. Help engine conversion into 4x4
    By dudoop in forum General
    Last Post: 26-04-2006, 03:12 PM
  5. looking for engine conversion
    By danny_sway in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-10-2005, 07:27 PM
