Results 1 to 9 of 9
Thread: spark plugs on vl 6cyl.
    vl & vr commodore
    Oct 2005
    adelaide
    Default spark plugs on vl 6cyl.
    just a simple question , do i have to take the air box pipe off the throttle body to change my sparkpugs , or is there an easier way?
    VL exec V8
    Jan 2006
    Thumbs up
    hi there markandsam, I guess you have a turbo 6, you can get a short wobble spark plug socket to fit but you got to have 2 or 3 one inch 3/8 extensions with a wobble end on them too and it just gets in there but be carefull putting in the new plugs not to cross thread them good luck
    vl & vr commodore
    Oct 2005
    adelaide
    nah , not a turbo , just looks like a pain in the arse to change over
    do they cross thread easy do they?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you can buy a t-bar with a uni joint on the bottom. i did mine with that. reasonably easy. do it cold though as they can be a bit tight while hot.
    VT SS S2 A4
    Aug 2005
    vl berlina wagon 6cyl
    Jul 2005
    I agree that the plugs can be a hell of a job, it helps to push a length of plastic tube over the insulator so you can start the thread by hand and reduce the chance of cross threading it, also be careful to keep the spanner upright and not put any pressure on the white insulator part which can easlly break
    a wobble or universal is most helpful
    also clean the muck away from where the gasket contacts the head
    yes the centre part of the airpipe needs to come off
    VT SS S2 A4
    Aug 2005
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    Quote Originally Posted by harry3
    what do you mean by "cross threading it"?
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    VP V8 Wagon
    Dec 2005
    Quote Originally Posted by Stewart1000
    cross threading is like stripping the plug.... making a new thread which isnt meant to be... should be okay just make sure u dont snap them when putting them in... i did it to my vl and didnt have time to put another one in to pick my sister up from work... 5 cylinders sucks...
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. best spark plugs to use
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 10:01 PM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. spark plugs
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2005, 08:52 AM
  5. spark plugs
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-09-2004, 05:13 PM
