Results 1 to 18 of 18
Thread: 02 sensor
    vl & vr commodore
    Oct 2005
    adelaide
    Thumbs up 02 sensor
    where can i find it , how can i change it & how much will it costs
    my cars using a fair bit of juice around town. have wound back afm to approx 382 ( was 70).cleaned the temp sensor too.
    VS executive
    Jan 2005
    just past the header, where they all meet into one. there is a little stick thing with a wire in it. it goes inside the pipe. that can unscrew i think.
    Half a carton and still going!!! Now thats Economy
    vl & vr commodore
    Oct 2005
    adelaide
    thanks buddy i thought it was that
    do you know how much they are to replace?
    EF Almost Turbo
    Jun 2005
    I know this isnt apart of your question, but how does one check the afm sensor?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    with a multimeter. its pretty complicated i've never done it myself
    ========My Statesman 20's Mafless and 3.9's========
    VS executive
    Jan 2005
    bout 120 if i remember right. thats holden one..
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    take the plugs off the o2 sensors, get a multimeter and probe the black wire and the purple wire on each 02 sensor. it should be fluctuating between 0.0 and about 0.7 volts when warmed up revving at about 2000rpm, so its gonna be some hot work unless you can find the wire that goes into the ecu. Id go and look at mine but its in the workshop at the moment. best to do it under the car jacked up with somebody keeping the revs up about 2000 rpm. the voltage should fluctuate a couple of times per second from 0.0 to 0.70. if one or both are sitting at around 0.7 they are either buggered or the earth is no good to them. you will probably find one is buggered and one bank of the engine is running in open loop mode and the other in closed.
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    each o2 sensor? how many are there??? and 120bucks, you'd think thats a bit steep considering its about the size of a spark plug...and i believe you have to have some sort of sealant for the new one...Was getting told the other day,(trying to recall) heat res. gal paint could prob do the job.?. also some sort of gluey sealant aswell.
    To check the afm sensor, pull the plug off connecting to it, put a multimeter (on ohms) across the 2 ends, on the little teeth things and get a reading of 382, mines 384 so i didn't bother changing it.
    VS executive
    Jan 2005
    one o2 sensor on an rb 30. maybe 2 on a v6. dunno bout that.
    Spastic Guest
    VT SS S2 A4
    Aug 2005
    Go aftermarket ECU with closed loop and forget all about your O2 sensor worries.
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Quote Originally Posted by Spastic
    Is it 382 ohms or 0.382?
    382 ohms or 0.382kohms you will see the k on the multimeter
    k is = to kilo
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Quote Originally Posted by rb26dett
    what r they worth and whereabouts would i be looking to find 1?
    VT SS S2 A4
    Aug 2005
    I think the only 2 who do it are Autronic or Motec.
    So your looking at around $3000 to have it fitted and tuned.
  15. #15
    JBVL is offline Retired Dirtbiker
    VL 1987
    Dec 2005
    Australia, QLD
    yep thats some good advice you've got there mate, only $3000 to fix our o2 sensor worries? Well you should of told us all earlier!
    We should all do rb26dett conversions while were at it yeah!?
  16. #16
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by JBVL
    Fixes the problem.
  17. #17
    megee83 Guest
  18. #18
    VT SS S2 A4
    Aug 2005
    Very bad fuel economy for starters.
  1. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  2. O2 sensor
    By CANYONERO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2006, 06:52 PM
  3. o2 sensor
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 10:46 PM
  4. cam sensor
    By I LIKE COMMODORES in forum V6 Development And Modification
    Last Post: 20-09-2005, 11:39 AM
  5. o2 sensor - how much, where from
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2005, 07:25 PM
