Results 1 to 3 of 3
Thread: how to undo the drain plug
    vl berlina wagon 6cyl
    Jul 2005
    Default how to undo the drain plug
    I couldnt get the cyl block water drainplug off my VL 6 cyl despite removing the front wheel and having a good collection of socket spanners, is there a secret to getting a spanner on this plug?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    its probably sealed in by all the scale and crap behind it. do you need to get it out? if you are just doing a flush disconnect your bottom and top hoses then remove your thermostat and stick a hose in where the thermostat goes and blast crap out. repeat with hose in bottom. keep doing both til clear water comes out. run a cooling system cleaner first to help break up the crap.
    Jul 2005
    thats what I finished up doing
  1. drain coolant
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-03-2010, 09:16 PM
  2. Block Drain Plug - Ecotec
    By conf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 07:50 PM
  3. How to drain the Radiator?
    By TheTeng in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2007, 08:38 AM
  4. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
  5. Coolant Drain
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2004, 05:41 PM
