Results 1 to 7 of 7
Thread: Cruise Control
    KCElectronics Guest
    Default Cruise Control
    Does any one know where I can find the Main Cruise Control box inside the cabin? and how big is it? (picture any one?)
    Chuckie
    calaisRB30 Guest
    Jan 2004
    If you mean the cruise control module it will be a black box located on the drivers side, under the dash, to the right of the steering column and to the left of the radio.
    If its the switch module it is another smaller black box situated behind the instrument cluster.
    -Mick
    KCElectronics Guest
    Default Thats the one Mad Dog
    Hey Mad Dog,
    thanks you are a star and you have nailed it It was the big one, I found the smaller one after following the wires from the switch , I have asked a few people and got all sorts of answer's , also do you know what the thick Vacuum tube from the servo unit under the bonnet is for? it states in my book that it is for a "Vaccum Brake Release Valve"?
    Chuckie
    Jan 2004
    If you are talking about the vacuum hose that goes from the servo into the firewall, yes that plugs into a vacuum release switch, which when activated will release the pull on the throttle and thus deactvate the cruise or reduce the speed.
    -Mick
    KCElectronics Guest
    Default Thanks again Mad Dog
    Thanks for all your great help with this , is this "Vacuum release switch" controlled by the normal brake peddle? or is it something else??
    Chuckie
    Jan 2004
    In VL's with cruise control the brake switch fitted to the brake pedal also included a cruise disengage switch so if the brake is pressed the system disengages. I believe that this switch on the brake pedal works together with the Vacuum Release Valve mentioned in the previous posts, in so far as if the switch on the pedal is tripped the valve in turn releases the vacuum pull on the throttle cable.
    - Mick
  1. VT Cruise Control
    By Apeman69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2009, 04:48 PM
  2. Cruise Control
    By 919 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-08-2006, 01:59 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
  5. VH Cruise Control help
    By A1oz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-09-2004, 02:50 PM
