Results 1 to 4 of 4
Thread: timing
    86 vl commo
    Apr 2005
    brisbane
    Default timing
    i have heard alot about advanceing the timing and i was wondering if anyone could tell me two things
    1st: what the procedure is (whats involved)
    2nd: what does it give you ie. peformance
    thanks
    Steve-0 Guest
    1- ya gotta get a timing light (thats the safe way) and turn somthing, i cant remember what it was, easy to do
    2-gives ya better acceleration but u do lose top end power
    VL RB30 Berlina
    Nov 2003
    the standard timing i 15 degrees btdc most people retime the motor to about 18-20 degrees...the way to do it is to get a timing light, connect the lead to no1 spark lead and point it at the crank pulley with the engine running. on the timing cover there its a little pointer and on the crank pulley there are lines that you will see. the fist one is usually yellow but it might have no color due to age. every mark after the first one represents 5 degrees.....just move it tile it on or near 20 degrees by loosening the slider bolt on the dizzy and turning it till the line is on the pointer and that's it(don't forget to tighten the bolt on the dizzy when you finish)
    Click the scales.....you know you want to!!!!
    86 vl commo
    Apr 2005
    brisbane
    thanks alot for your help i might have a go at that it the next couple of days
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. Timing
    By krisjanik in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2006, 09:21 PM
  3. cam timing
    By aghatas in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2006, 08:30 PM
  4. vs v8 timing help!
    By mean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:52 PM
  5. timing
    By vn series 1 owner in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 07:50 PM
