Results 1 to 14 of 14
Thread: ecu diagnosis DAMN
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Angry ecu diagnosis DAMN
    I just fitted a stacker the other day and my missus took the car for the first time since that. It wouldn't start at first, left it a couple of minutes and then started first go. after that the car kept stalling (auto) and she had to keep playing the throttle to keep it alive. I then did an ecu diagnosis and it came up with code 11 and 14. crank angle sensor and speed throttle sensor. book says to fix CAS first as it sets off other codes. I reset the ecu with brake peddle and took for small drive and nothing happened. No stall. The CAS contacts aren't great due to water corrosion but not too bad either. I think the stacker issue may be coincidence. I hear the CAS are very dear. What to do????? The car used to stall cold too but changed ecu for chipped one and it stopped. started again, while driving though, months later. changed fuel filter and it stopped again. now this......could it have been the CAS all along?
    :b:
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well i just went up the shops and nothing happened. but i don't want it to happen again while my missus is driving.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    If it is the CAS the car will die and not start again and the car will be stuck where it is, if you can clean the corrosion you may get another few thousand k's out of it, The speed sensor is a normal code to get when you start the car and it will cancel when the car reaches a certain speed. The CAS is around $100 from holden I believe. And if you get some electrical tape and tape up the plastic cover around the wires nice and tight it should stop dust and water from entering the CAS.
    ========My Statesman 20's Mafless and 3.9's========
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i did it by the book, you are to drive the car (in diagnosis mode) over 10 km/hr to cancel it, turn car off, turn key to 'on', depress accelerator and release, put gear from neutral to gear and back to neutral. these get rid of speed sensor, neutral position sensor and another one i can't remember the term for (drinking). the others cancelled except speed sensor and CAS. supposedly CAS can sent off other fault codes. i just wish i knew for sure whats wrong.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Which book are you using because a friend and I had this problem and the books were different in listing the fault codes, I had the gregory's and he had the Max ellery. and to this day we still don't know which is correct.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I agree but this one was given to me but I rarely use it when instead I can google or come here to find it out. I had the max ellery torana book for my last car and it was excellent.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    the cas isnt that expensive but if you dont have the tools and knowledge to do it yourself then it can be expensive due to labour costs
    im not admiring your car im looking in disgust
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    good to hear. some idiot told me it was really expensive and i was freakin out.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    Have i got story's about that F*kin CAS. My car used to stall while i was driving, i would just pull over and start it bak up, all good but one night it didnt just start up again. so anyway it gets toe'd to Holden ***The holden dealers in my town Rip u off somthing fierce AND dont do the Job properly, Very bad reputation up here*** So anyway they replaced the CAS and the cost of the part was $167 or around that, and the labour i was charged was about $160 aswell. Thats alot of money to spend on a little sensor. So antway im drivin about 2 days later and the car stalls again, wont start. Turns out they Didnt screw the Distributor up tight enuff so it came loose and started wrecking stuff inside. That cost another $150 odd
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Dec 2005
    Nsw - Taree
    nope, we know the auto elec really well so he overcharged us and then we gave Holden that bill
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    The cas can be intermittent. Mine wasn't showing up as a fault code when mine was playing up. However thats what was wrong with the car. It would start and run really rough and it had to keep the foot down on the accelerator, but even then it was hit and miss and it coughed and choked quite alot.
    Leaks in the inlet will also give you something similar to what your talking about, or a battery not gripping tightly enough.
    If it is the cas make sure you get the bearing changed aswell, I think I've seen kits for 130 dollars including the upper boot with plug connector. I myself fell victim to rip off auto electrians when my cas went a couple of years ago.
  1. VS fault diagnosis not working
    By VPbomb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2007, 04:15 PM
  2. diagnosis of water pump
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2006, 08:04 PM
  3. Self Diagnosis help needed...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2006, 12:46 AM
  4. Overly Educated Diagnosis
    By rattattack1313 in forum Jokes/Humour
    Last Post: 30-10-2005, 08:21 AM
  5. Self Diagnosis
    By timboss04 in forum V6 Development And Modification
    Last Post: 07-10-2005, 02:27 AM
