how do i ajust the clutch on my vl? it has too much free play, i did a search and found nothing.
i know series 1 couldnt be ajusted but mine is series II im pretty sure, its got the colour coded center inserts, and its '88
anyway, how do i ajust it and how much free play should it have?
thanks guys/gals
p.s. its been on my mind recently, how to G-Techs work? they dont plug in... i didnt think so how does it tell your RPM, cant be by sound cos what it you have other sounds in the car, speed is through gps yeah? i got no idea really, just curious cya.![]()
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
are the vl's hydrolic clutches?? if they are all youll haev to do is bleed it like a brake system
im not admiring your car im looking in disgust
really? no ajusting any bolts or nuts?
sounds like i could do that easily enough, where it the fluid container, or does the break fluid serve the clutch aswell?
master cylinder near the brake booster. G-tech works through a mercury reading to tell you G-force. then through physics formulae determines distance over time (acceleration) through the g-force placed on it as well as top speed.
the clutch fluid container will be right next to the brake but is definatley a seperate container
but how does the g-tech determine RMP?
i don't think it does, but then i haven't seen one for 8 years.Originally Posted by Stewart1000
ooh ok, i still havent figured out the clutch, things are probably just worn out, the pin hole is worn
you'll know its worn when your foots almost to the floor before the clutch disengages. and when you give it a bit changing gears and the clutch slips (engine revs but car doesn't accelerate for a moment)
yeah it hits the floor while changign gears but changes really nice
i actually just went for a drive from devonport to sheffield and back in it and damn it goes hard... (thats tasmania btw) even eith the worn clutch. im clocking up the hours while im over here, roads are pretty shit tho
lucky, learning on a commo, i have to learn on a damn 7afe corolla, i spoze atleast it chopps pulsars and astras
