Results 1 to 10 of 10
Thread: auto and manual diffs
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default auto and manual diffs
    i was tolled last night by a mate that may car has more piortental 2b quicker,
    he said that if i had manuals diff on it would b quicker,
    is there such thing as a diffrance in the ratios in a manuals diff to a autos diff?
    and if so would it make much differance?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    tell your mate he's full of crap and to get his hand off it. it's the same diff ratio across the whole board except for the 5.0 litre. auto and manual n/a 6cyl and turbo 6 cyl including LSD all have same ratio of 3.45:1 whereas the v8 auto and manual has 3.08:1 which gives quicker acceleration.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    ^^^totally agree with bangers, the diffs are identical, the turbo diffs are different but only with the splines and pinions, the ratios for all 6's are the same 3.45.
    NA diff is 25 spline 2 pinion
    turbo diff is 28 spline 4 pinion.
    LSD might make your car quicker through the corners but not really in a straight line unless you are frying your tyres off the line.
    and the 3.08.1 is a slower accelerating ratio, more top end tho (highway). 3.45.1 is a great mix of acceleration and top speed. (new monaros have 3.46.1)
    ========My Statesman 20's Mafless and 3.9's========
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    Quote Originally Posted by VL Berlina 5speed
    Yeah it's total crap. You want the car to be quicker get a better ratio diff. the quicker the car accelerates the quicker it'll be but the lower your top end speed will be.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by ucwepn
    forgive me i've a few coldies but isn't the shorter diff quicker acceleration. as the diff turns less times in ratio to engine in comparison with a taller diff. ie 3.08 is quicker acceleration than 3.45. correct me if i'm wrong mate.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Bangers your on the right track there but (and its strange how this works) The taller the diff ratio the smaller the number. so just say you had a 2.75.1 it would have bugger all acceleration and would probably hit 300km/h lol. And 4.11.1 would have supreme acceleration but would run out of puff at a lower speed. Gran turismo is my teacher LOL.
    Oct 2005
    in a diff with 4.11 ratio wat would be the top speeds u xpect to hit and what car are these out off?
    and wouldnt its revs sit ultra high at 110kmh?
    mine (3.45) sits on 2000rpm at 110kmh so if i had a 4.11 in it would the revs b at bout 4000>5000 and use more fuel?
    wats do yous recomend for a ratio? i want better accelration BUT i dont want my cars revs to sit 2high when at 100>110kmh
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    VT SS S2 A4
    Aug 2005
    Oct 2005
    Quote Originally Posted by rb26dett
    Maybe some 3.9 diff gears?
    wat are these out off?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    find out the diff ratios out of similar cars that the diff centres should bolt straight in to your vl. i don't know much about the other commies so someone here place your advice on this, but i was thinking maybe early model commies or even VN.
  1. auto or manual 5.0
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2007, 03:04 PM
  2. auto to manual?
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2006, 07:55 AM
  3. vn manual 4 vr auto
    By SYM35 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2005, 09:49 AM
  4. vn manual 4 vr auto
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2005, 07:00 PM
