Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Thread: Turbo front brakes on an NA
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Default Turbo front brakes on an NA
    Hey all I have scored some turbo front calipers and am going to get some 11" turbo discs and fit it all to the front of my NA, My question is this: Will I be able to use the stock master cylinder? as I have drums on the back, and I fit a 1" master cylinder will this be too strong for the drum brakes and cause them to lock easily? I know there is some gain to be had from fitting the vented finned calipers and larger disks and want to gain some braking power until I can afford to do the disc diff.
    ========My Statesman 20's Mafless and 3.9's========
    VL RB30 Berlina
    Nov 2003
    you can't use a 1' master on drum rear end.....there's something different about them but i can't quite remember.....it would be best to buy a disc conversion kit and convert the rear to disc......then you can fit a 1' with no problems. as for the turbo calipers with the standard in my opinion they probably won't work all that well
    Click the scales.....you know you want to!!!!
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i hear they work really well. so much so you don't need the rear discs unless you turbo or v8 it. get slotted discs too but not cross-drilled as the cross-drilled ones can crack between the holes.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by bangers
    there are some new discs out that have holes casted in, when the moulds are made they have high spots in the moulds to make the same holes thats in drilled discs,
    ive been toled these are strong and arnt prone to craken.
    is this referring to this \/
    Quote Originally Posted by seventh path
    coz if u r that would awnser a question i had askd a while ago about using a standned VL master/booster with vt twinspots and 296mm discs
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    in answer to your vt twinspots i myself wouldn't bother. the new hubs needed change the offset of your wheels. plus the vl turbo brakes are more than enough to pull up your car. get the turbo discs then go to repco and get colour coded PBR calipers. they are twin spot too and just bolt on. and the coloured calipers look great behind nice open rims.
    Oct 2005
    how much dose the off set go out, would it cause 18s to rubb
    WTF i thought i needed to getm from wreckers and i couldnt find any
    how much rufferly are these not colour coded and colour coded
    i got these vt 2wins spots and discs 4 free so i thought i would try using them
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    i don't wonna state the ovios you need to change the hub as well
    otherwise the caliper wont clear the rotor
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by burnz
    thats what i said, the new hubs change the wheel offset. now as for 18s rubbing, it depends on the offset of the rim and if the car is lowered or not and if so how much is it lowered by. some rims it's a no go, some you can roll the lip of the wheel arch and others you might have to flare the guards abit. if you have to flare the guard its not worth it cos the paint will crack and you'll have to respray them. if you have the vt ones there for free you can give em a go. if the wheels rub then it'll be cheaper to do vl turbo brakes instead of get new rims. as for cost of colour coded PBR's its about $180 from memory including pads, and i haven't seen non colour coded ones. colour code looks really good, i've seen brand new Statesmans with them at Holden By Design workshop. There's black, red, and i *think* blue and also yellow. Not a great deal of cost difference once you take into account VT pads and also new hubs to suit. Plus VL discs are about $180 as well for the pair I *think*.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Sweet thats what I thought and I would like braided front brake lines as well to go with my turbo front brakes to reduce fade even more. I'm not a race car driver just like to give it a squirt sometimes and it would be nice to be able to stop harder as my car now goes harder.
    I want to know about reconditioning calipers, like where can you buy the kits? is it something that can be done by me? and how much do they cost?
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    I have found this great "how to" by jetspin but all the photos are gone, whats up with that??
    VL -> VLT Brake Conversion
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    you'd robably score a kit at repco or someother spareparts store. i wouldn't bother trying at autobarn or supercheap.
    Oct 2005
    cheers bangers, u anwserd my questions that no 1 else could and its much apricated
    cheers sean
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    VT SS S2 A4
    Aug 2005
  15. #15
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    better than standard vl brakes, well i hope so. i just said they weren't necessary. vl turbo brakes are more than enough to pull up a n/a vl. People only put vt brakes on because they can. I'd go the VT's as well if i had a bullsh*t hot turbo that was pumping out 600 horsepower plus. But then again maybe not, the difference in disc size is tiny and you put twinspot PBR calipers on and they really are just as good.
  16. #16
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
  17. #17
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    hey bex. from memory they are 180 including pads. don't quote me on that. just call repco.
  18. #18
    Oct 2005
    i stopd at repco 2day and askd and was tolld 179 EACH just the caliper NO PADS or new hose thats for the standerad vl brakes new, and the dude said vl turbos calipers are the same just finied. i thought they were twin spot, if there not twin spot i will b usiing the vt brakes i have got coz it would work out cheaper
    vt>vl hubs 250bucks new
    pair of front vl turbo calipers 360 bucks
    new pipes for brakes 45 bucks each
    then some discs 100+bucks each
    so looks like the vts will go on eventully
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  19. #19
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Yes STANDARD turbo calipers are finned. The PBR are twinspot. You shouldn't need hoses. And the repco up the road does them as a kit with Ferozo pads. And you don't have to worry about new hubs and bearings. And the different offset. I was off with the price, sorry, i was half right at 180. just each not the pair.
  20. #20
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
  21. #21
    Oct 2005
    ok, my bad 4 got to mention i was lookn 4 PBR to the dude,
    if new hose lines are 45 bucks new then wat would the price off braded lines? 80 bucks
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  22. #22
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i don't think the guy you were talking to is on the level. i researched the disc sizes while working as spare parts interpreter. i know the guy at repco i spoke too as i did stocktake with them. and i also spoke to a mate at mcarthur tyres. and all he does all day is brakes and suspension. I already said if you have the VT brakes by all means put them on. i wouldn't BUY them myself. If someone gave them to me... sh*t yeah i'd put them on too. I'm just concerned of the change in offset. i wouldn't mind someone here enlightening me.
  23. #23
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Turbo calipers will not fit NA discs and vise versa, turbo calipers are very similar to na ones except they have the fins and some vents that the na does not. This aids dispersing the heat allot better than the NA calipers and also the turbo discs are 1 inch bigger than NA discs which will also aid stopping power. I got the calipers for $19 so I'm not complaining I will get a reco kit and some slotted rotors and fit them up.
  24. #24
    Oct 2005
    ...sh*t yeah i'd put them on too. I'm just concerned of the change in offset. i wouldn't mind someone here enlightening me.
    off set isnt that they total width of the wheel base side to side, coz if it is i will just have to rool the gaurds as my 15s are almost touchn allready
    im not sure if theres any kits to fix this but i will findout soon,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  25. #25
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    turbo PBR calipers shouldn't be finned. they just house the normal turbo pads. so essentially they should be bigger than the nonturbo PBR calipers. what i meant by all the above is you can go and buy turbo pads and they'll fit straight into a PBR caliper (as long as they are the turbo caliper). you don't have to buy special pads.
  1. need help with front brakes asap!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-11-2007, 05:24 PM
  2. front brakes giving me the *****
    By Burnout_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2007, 06:50 PM
  3. need help with front brakes asap!
    By boourns in forum V6 Development And Modification
    Last Post: 11-05-2007, 01:20 AM
  4. Bleeding VT Front Brakes.
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2007, 11:20 PM
  5. VS to VY front brakes!
    By spac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2005, 02:31 PM
