Results 1 to 2 of 2
Thread: water pump issue
    vl executive
    Jan 2006
    Default water pump issue
    hi i have just bought a new water pump for my vl and have removed the old ones and i forgot what one of the screws go into this hole :b: its the one what is at the end of the water pump the little one that is in the middle of the two big ones (seems like this screw dosent go into the block i think its a bleeder or something) please help if anyone can
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    its an M6x1.0 the bolt with the long nut shaped head. it should be the only bolt shaped like it. The 2 bolts with the longest shank (shaft without thread) go top left hole and the hole to the left of it. the 2 bolts with a shorter shank than the last 2 go the in the 2 holes at the bottom on the left side. the bolt with the long head goes top mid. and the 6 bolts without a shank go in the 6 holes on the right.
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  3. Water Pump
    By VScom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2007, 11:12 PM
  4. Fuel Pump & Window Issue.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 01:29 AM
  5. Fuel Pump issue
    By Ton-Fun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:04 AM
