Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: seems like timings out
    87vl
    Jan 2006
    Unhappy seems like timings out
    car is backfiring, running like it has only five cylinders will idle good sometimes and runs well then just die but will still idle, if you accelerate it dies or wants to,wait it will start and run well but returns not long after ,new fuel filter, changed internal pump of fuel tank new plugs and leeds does this sound like cas as this is what ive been told driving me crazy lol hellllllllpppppppppppp
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    usually when the cas stuffs out the car won't run at all. usually. Hows the dizzy cap and rotor button. might have a fouled up points.
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    87vl
    Jan 2006
    it did have speed sensor code and air con but reset and have gone not returned
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    87vl
    Jan 2006
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    maybe your CAT is blocked too? how old is it? if leads and plugs are stuffed then the car will run rich and that chews out your CAT. possibility.
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    catalytic covertor. at the end of your exhaust manifold. it joins the manifold to the exhaust pipe.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Catalytic converter (on the exhaust under the passenger seat). It sounds to me like it could be the Air flow meter. Its always the same things that go on vl's, CAS, AFM,fuel pumps, O2 sensors and coolant temp sensors.
    ========My Statesman 20's Mafless and 3.9's========
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    we've eliminated the sensors effectively. All thats left really is the AFM and the CAT. i'm just sussing out the CAT first.
  15. #15
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by ghostmobile
    i have extractors
    you'll still have a CAT though. it'll be at the end of the extractors. if it rooted it'll make the car play up cos it gets blocked. when it totally collapses the car will be lucky to go 20km/hr. so is it old?
  17. #17
    87vl
    Jan 2006
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    are you sure it wasn't replaced from the CAT back. The whole thing was done from extractors to exhaust tip?
  19. #19
    87vl
    Jan 2006
    no just went out and checked is bloody old but would the car go well and die occasionally?
  20. #20
    87vl
    Jan 2006
    picking up new dizzy tomorrow wont hurt as it is old anyway
    is there a way to test if it is blocked other than taking it off?
  21. #21
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    yep. that could be what your problem is. best way is to buy new gaskets for it and pull it out and have a look down the guts of it. the wire mesh inside will be all bent instead of dead flat. i reckon shes your problem.
  22. #22
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    gaskets aren't expensive. at the same time though you'd probably get them when you buy a CAT so keep the receipt incase you do need to buy a CAT and the gaskets come with it. If you end up needing a CAT buy a hi-flow one and put it in yourself. You may get a lukey one from repco. exhaust shops will charge about 300 to replace. might get one for 150 or so if luvky and throw it in yourself.
  23. #23
    87vl
    Jan 2006
    thx for your patience bangers very much appreciated,the wife thinks i can look at car and tell her whats wrong straight away her f.... up attitude been pissing me off as we dont have alot of money really and i feel this pressure if i get it wrong that i just wasted money really dont help the brain to think but thx heaps i may aswell do cat anyway hopefully that ll fix it
  24. #24
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well for your sake i hope i'm not wrong then. we must have the same missus! goodluck. as i said pull it out to check first, and take it to someone if your not sure to confirm its rooted.
  25. #25
    87vl
    Jan 2006
    cheers so u dont need a wife then lol
