hey all. I need to remove the front doors off my girlfreinds VL
do i need to unblot the hinges or is it a case of removing the pins?
Lee
Disconnect wiring etc. remove door panels & push them through opening so out of the way, then tap the pin upwards(door stop assembly). Have a jack(preferably floor jack& use rag to protect paint) under door. take hinge pin covers off, then it gets tricky.Need to take the hinge sleeve out.
Refitting is the reversal... GOOD LUCK.
