Results 1 to 10 of 10
Thread: Stall Converter
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    Default Stall Converter
    Any1 ever put a stally in their box? if so how big and did it make much difference. I have a 5 spd here to put in but im thinkin about shift kitting a auto box i have here and puttin maybe a 2500 - 3000 stally on, not sure.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow Hi Stall
    You can't just pick an rpm range, it all depends on the cam ur using..
    Ask me if you have more Questions....
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Dec 2005
    Nsw - Taree
    i wasnt picking a range, i was saying i would get any stally around that rpm eg. a 2800rpm stally or a 3000 stally etc etc.
    Jun 2005
    South OZ Adelaide
    Lightbulb stall
    what cam do you have??
    Dec 2005
    Nsw - Taree
    atm standard, not sure what im goin with yet, not even sure if i'll do the stall convertor in the auto thing, i was just curious as to how well it would go compared to the stock box
    Jun 2005
    South OZ Adelaide
    Thumbs up stall
    Ok there's no point doing a stall converter with standard cam!!
    Say atm with auto the car gets going at 800rpm and revs to 5000rpm,
    you have 4000 usable rpm and if you put a 3000rpm stall in with the std cam you'll fly from a start if you nail it but you now only have 2000 usable left..
    So say you put in a nice cam that starts working from 3000rpm and revs to 7000rpm then you need a stall of 3000rpm making power all the to 7000rpm...
    The hotter the cam the higher up the rev range moves from where the power starts and where it drops off.
    Oh nearly forgot diff ratio needs to be changed and a heap of other things too!
    Hope that makes sence for you??
    If you are sticking to a std cam by all means get some work done on the auto, tougher parts-harder gear changes from shift kit ect..
    And 4 other readers do you know of a auto car with a HOT cam that stalls every time it's put in gear when cold and has to start it over and over again then it's gutless until the revs get higher - well that car needs a stall converter.
    One more thing you CAN take off from a stand still like normal and it's good to be able to take your foot off the brake pedal without the car moving foward like ALL std autos do. I'll shutup now
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    if u get a cam in a manual is a stally needed? as im running out off things to do and a cam is lookn like the next step
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Jun 2005
    South OZ Adelaide
    Arrow stall
    If ur going 5 speed and a mild cam the manuel box will be fine, go to hotter cam and it will be a pig to drive..
    Jun 2005
    South OZ Adelaide
    Thumbs up stall
    and you can only have a high stall converter in a auto...
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah a torque converter is only in the autos not manuals, they are needed so you can stop and not stall
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  1. What does a stall converter do?
    By J_D in forum General
    Last Post: 23-03-2007, 08:04 AM
  2. How to ID a stall converter
    By skootaroo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2006, 12:54 PM
  3. stall converter
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2006, 09:33 PM
  4. Stall converter
    By andy 308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2005, 03:03 PM
  5. Stall converter
    Last Post: 03-04-2005, 01:11 AM
