Results 1 to 12 of 12
Thread: G-Techd
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Unhappy G-Techd
    last night i tryed my car out using a gtech i managed a 16.82 but i dont get it. i can bet my mates 318is bmw in a drag and he can run 15.63, so how come my et time would b slower?
    the air temp was 22 degrees last night so it was fairly cool
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    98 VT S pack Supercharged/ 77 Datsun 260z Rb20det
    Jul 2004
    Mackay
    Was the G-Tech properly calibrated for both cars?
    1998 Holden Commodore | Supercharged 3.8 V6
    1977 Datsun 260z Sport | RB20Det Engine Conversion
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    theres too many variables with it. Road condition, weather, even down to driver ability. only way to really see, is have both cars at the track on the same day, then swap drivers and work out the differences.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Oct 2005
    the mate off mine drove my car and got that time and hes the bmw owna
    if i tryd i would xpect beta time coz im more use to mine car
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jul 2004
    Mackay
    Were you both using the same G tech unit. Did you recalibrate between the 2 cars. Ie Weight ( Means taking your car to a public weigh bridge) and was the unit mounted corectly. Do you think that both cigerette lighter sockets are working properly (ie no neon lights or double adaptors.)
    Oct 2005
    Quote Originally Posted by blue alliance
    yah same unit 94 model,
    and i dont think it needs ur cars weight coz its only got 1/4, 0-60 and hp features theres no advance features,
    u mention neon ive got 1 in the boot should i disconnect that and my amp or would this have no affect
    need some quick help or ideas goin 2 try again tonight
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Jul 2004
    Mackay
    Yeah i say Neon cause some of these things can piggy back into the lighter socket. Also if it doesn't require the calibration (ie weight input) then that might be why the readings aren't so accurate. From memory the good ones require a bit of calibration.
    VP Executive R-spec
    Jan 2005
    You crazys
    You do not need to weigh anything to get an accurate reading on a g tech, all you need is a flat bit of road and something to stick it on. It works on g forces, accereration through time and all that. The onyl time you need to weigh the car is to read rwhp but that comes with wind resistance so will be much less than on a dyno, My almsot stock Lexcen V6 has a best rwhp of 134 in second gear on the g tech which is about 150-160 rwhp without the wind. somewhere near 120 rwkw... or almost 200hp at the flywheel which is about right for the 15.37 @ 91 mph it can run.
    Anyway for a VL non turbo? you could maybe get down to 16.4? I don't really know but they are no where near as fast as a VN/VP. Not sure about the BMW but I don't think BMW like to make slow cars so 15.63 sounds fair enough
    Oct 2005
    Quote Originally Posted by greenfoam
    u sure ive bet a vn executive auto
    i dont just under stand i can beat him in a drag (start leaving him in second gear bout 2 car lengths when hit bout 100kmph)
    but 1/4 time is wierd
    .............BMW 318IS..........5SPD BLNA
    DRAG.........loses...................win
    1/4 time......15.63.................16.82
    WTF i just cant figger it out
    (Mate did both the 1/4 mile times) could b mines slower coz hes not use to a lower class car ( ). next week i will try it 4 my self as last night i couldnt SMASA cruze was on
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    VP Executive R-spec
    Jan 2005
    You might have beat a VN Auto, but it was either stuffed or at half throttle , I'll promise you they can all do sub 16 seconds anytime anywhere if they have traction and are working properly (and manualy shifted from second to third) do that and a good VN auto will run 15.5 all day.
    If your car is quicker than a stock VL and your mate can't shift manuals fast or lost traction on the launch then you can loose more than a second from those things easily.. so you better test it yourself If my VN gets wheelspin for even 10 meters I'll run slower than 16 seconds, get 100% traction and it will be under 15.4, it makes a big difference
    Oct 2005
    supoz i it had mass wheel spin, left a mark bout 15 meters long on 1 side and bout 5 on the other
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    megee83 Guest
    it all comes down to the day doesnt it? if you get 16.82 one pass, doesnt mean thats the best it can run... like you said, your mate was drivin so he not gonna be used to your car for starters. jus keep at it an see if you can get the times down...
