Results 1 to 8 of 8
Thread: vl power cuts
    vl executive
    Jan 2006
    Lightbulb vl power cuts
    I have had trouble with my ol' girl cutting out on me some days. I've had auto electricians and all sorts of mechs look at it with the same reply "that's really weird!" I'll be driving along, tromp on the accel pedal and she dies on me, usually at 60, 80 and 100kph. Finally I thought that maybe the alarm that doesn;t work any more (goes berko when on) might be activating a kill switch or something so now I just give her a little spank under the red button and we're away again. Does this sound like something anyone else has heard of?
    87vl
    Jan 2006
    sounds similar to mine happening for over six months i changed everything nothing changed,in the fuel tank is a low pressure pump clean sack on bottom of that also a rubber fuel line joining this pump to steel fuel line in tank mine was ratshit changed that run good now, had everyone stuffed,when fuel is above this steel line the high pressure pump could still suck fuel but when fuel low would die,would idle but press accelerator would die,let me know how you go
    vl executive
    Jan 2006
    vl executive
    Jan 2006
    although have had fuel lines etc checked, throttle position switch changed and still stumped. Will try and clean it out though and let ya know.
    cheers
    87vl
    Jan 2006
    the fuel line that i had to change was inside fuel tank just making that clear,good luck as i know how it feels
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by jeddabum
    Kinda sounds like you answered your own question, you hit the little red button that you've got for the alarm? And it works again?
    vl commodore
    Oct 2009
    Default my baby's sick
    Im having some troubles with my VL-its my pride and joy had it for 11 yrs now. I have stopped driving it recently- getting abit old now. Its stock rb30 series 2 block auto. not many mods- just extractors, cold air intake-thats about it.
    Running abit sick now-ill be driving and ill loose power.The car will be running but i cant accelerate and loose power.I have to brake/slow down and power might kick in again and if that doesnt work i have to pull over and re start the engine and shes all sweet again.other times while im driving it'll just stall with no warning at all.
    Ive taken it to an auto electrician,they had it for 2 days but they couldnt fault find cause the fault happened too quickly for them to fault. They suggested it may be the C.A.S but i dont think so.
    If anybody has any idea what it could possibly be, would be great to hear from you.
    If i cant get this problem fixed im thinking of chucking a v8 in but converting a VN/VP ss motor into carby cause injected is too hard to fault.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    could well be your CAS bud..
    very temperemental they are... CAS can just sh#t itself,, or slowly fail..
    i would try another CAS from a working vl to c if that helps.
    could even br your AFM failing as well. these 2 componants play a major role on the commie..
    and as they are 20+ years now many other elec systems are prone to stop...
    at first i would try cleaning CAS plug on top of dizzy as i know this plug corrodes out(green corrosion) then spray with RP7/INOX/Wd40 as well as all other electrical plugs..
    there is a starting point.
    How are the Leads and PLugs rotor arm and dizzy cup contacts clean/replace if necessary
  1. Air con cuts out
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-01-2006, 05:39 PM
  2. Fan cuts out VC
    By Outlaw Torn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 08:03 AM
  3. Car Power Cuts Out!
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-07-2005, 11:08 AM
  4. Vl cuts out
    By v8bike in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2005, 07:35 PM
  5. Power Cuts Out?
    By Phillbert in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-03-2004, 11:15 PM
