Results 1 to 10 of 10
Thread: vl turns over but won't bloody start
    jolea68 Guest
    Angry vl turns over but won't bloody start
    Could someone please tell me what is happening to my car. The other day driving along and lost power in excellerator and then car wouldn't start, turns over everytime, wiggled wires to fuel pump and then it worked, but only once took to electrician he changed crank angle sensor, all good for two days and then it all happens again, there is noise coming from fuel pump, and alarm is turned off and it has spark ? cheers Jo
    VL Berlina soon to be turbo'd
    Mar 2005
    Whyalla ..
    Default Not Starting
    hi there on the battrie termanal + there is 2 plugs at the back of itone of themis for the fule pump check that is not correaded take em boath out and make shure the connection is a copper colour not a dark colouror or a plain white just get a flat head screw driver and scrach the copper may help u out
    there is also anothere connection up the back behind the drivers side wheel
    u should check that one too
    also my car wouldnt start for 2 years and i found out it was the hoses from the throttal body to the top of the motor letting in air. And petrol was not getting in cause comp was telling the car to mutch air not enought petrol getting to injectors i replaed hoses started instenly ?
    so check hoses and battrie termanal plugs under the red terminal couver
    tell me how it goes its better to spend bugger all first and find out the prob with little test than spend a heap on parts and find out bugger all
    vn calais
    Jan 2006
    vn calais
    Jan 2006
    i think it could be your computer playing up. Get a new one from the wrecker for $50 bucks
    87vl
    Jan 2006
    Talking
    well similar sounding to my prob if accelerate it dies?in fuel tank is a fuel pump aswell, the hose joining this to fuel line had perished changed it goes well,this prob had been happening for 6 months easy changed everything,the fuel was sitting abve steel fuel line so we think the outside pump could suck it up but when hitting under half tank would play up,let me know how it goes also on the fuel pump inside tank is a mesh sack give that a clean aswell
    DenchY is offline project status = ongoing
    86' VL 323ci
    Mar 2005
    Newcastle
    its staving for fuel.. if u push gas and it dies like u said.
    i'd be checking the fuel filter then the fuel pumps, then computer
    at worst it could be blocked injectors.. that happens now and then
    gl
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    well try taking out the fuel reg and see if fuel comes out under pressure and if it doesnt then investigate further down the line towards the tank
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    My Car Pwns's Avatar
    My Car Pwns is offline 16 Mths Suspended Lisence
    Fully Sick Push Bike Uleh!
    Jul 2005
    check fuel lines.. to see if petrol comes out, if it does, let it all come out (whatever wants to squirt out) you've probably flooded the engine trying to start it so many times.. this happened to me last week..
    I wonder what those scales on the top right side of my posts do...
    VP EXECUTIVE 3.8 V6 t700
    Jan 2005
    Armadale Perth
    Default wont start
    Quote Originally Posted by jolea68
    crank angle sensor changes are a quick buck for sparkies, any way loop the pressure sensor for injector rail straight to inlet, by pass that crappy solenoid and make sure the power transistor sitting on the dizzy connectors are tight, one is an odd type, if you have to, replace one at a time with standard female insulated terminals so you dont get them back wards, another thing i found out, also resposible for high speed miss, that 50 cent part, with no number on it, convenient Mr nissan, runs the whole shooting match including crank angle sensor, coil, and talks to ecu, hope this helps, mine doesnt go now, ran out fuel having fun. remember the fuel pressure sensor loop to plenum! stops fuel starving, if you cut out again pull out number 2 relay under bonnet the one onleft and pop in/out it will trigger the pumps to pressure injector rail, usually works, untill you loop sensor
    thestash_16 Guest
    check the EFI fuse!!!!
  1. car turns off
    By BOXTROT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 01:15 PM
  2. air con / fan cant go to 4 (turns off)
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 06:15 AM
  3. car intermittenly turns on
    By kluckmeister in forum General
    Last Post: 08-01-2007, 09:24 AM
  4. VT turns over but will not start
    By brettm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 01:02 AM
  5. Help. Air con fan turns itself off
    By veeque92 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 06:57 PM
