Results 1 to 10 of 10
Thread: my vl wont rev
    justkav Guest
    Default my vl wont rev
    hey guys i have a vl and it wont rev over 2,000 rpm its ok at idle but when u get on the gas it chokes and breakes down now i have checked the air flow meter thats fine i did change the crank angle sender but not sure wether it works 100% please can any one tell me what the hell is wrong with it please?
    plugs have been replaced and fuel filter has been checked fuel pump has been renewed as well cheers
    87vl
    Jan 2006
    did u check fuel pump in tank?on this pump is a sack might need cleaning,mine had same problem it turned out to be a 1inch fuel line attiching pump in tank to fuel line,you will find this inside fuel tank, next to the pump under rear end is a circle plate with about 6-8 bolts 8mm i think, that is attached to fuel pump take that out check line and sack good luck let me know how u go
    vl
    Feb 2005
    Most trouble when it won`t go above 2000 rpm it is in limp mode .easy way to test is unplug lead to AFM and start car if did does the same i would suppect the AFM, If you have friend that has another VL try swapping AFM and if it comes good then you know .
    VL RB30 Berlina
    Nov 2003
    check the air flow meter plug.....they can stuff up too and cause the same problem
    Click the scales.....you know you want to!!!!
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    Ah I may have the answer. Can you tell me if the car was running ok before you changed the crank angle sensor? If it was you may have done what many inexperienced people do and put the rotor plate upside down and the car will still run but very poorly. If this does not help then possibly yes the high pressure fuel pump may be faulty and not running as they do have two pumps! Hope this helps
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    mine done that after the water pump shat itself when the mech reset the computer it was fine
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    sounds like somethgin to do with the afm, it could be as simple as cleanign the connections. what you can also do it test the resistance
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    VL turbo & VT SS 5.0
    Sep 2005
    try the wiring to the AFM and spray the plug connection with WD40, also the resistance between pin 1 and 6 should be approx 381ohms, adjust it by turning the screw, if you cant see the screw smash that plastic cap/plug with a screwdriver.
    cheers
    justkav Guest
    thanks guys i figured out the problem was the crank angle sensor now it run relly well cheers kav
    megee83 Guest
    i had the exact same prob with mine and was the AFM, jus wondering if this is a symptom of a number of engine management problems, ie if the same thing happens as a result of faulty AFM, CAS, other things also? anyone know?
    also id suggest a good place to start with any electrical problem in the future is the computers self-diagnostic function , can save you the hassle of needless stuffin around.
  1. help with a vn that wont run please
    By 078commyboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 04:34 PM
  2. V6 wont rev...
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:16 PM
  3. wont run
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 10:24 AM
  4. Vn wont rev
    By wilca014 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 12:48 AM
