wat dus a shift kit do
a shift kit is to make the transmission shift faster by changing the valve bodies and pressures
Click the scales.....you know you want to!!!!
its a good idea if you like to put the foot to the floor in an auto, ti changes faster and smoother, and more reliable changes
my web sitestuff on the XF throttle body conversion, calais interior and lots of other junk!
wat dus one cost
not sure, you could just have a look on ebay and they will probably have some for sale
one of my friends got on(serious overkill) for a stage 2 for $600.....you could probably get one cheaper though
i wood like to get a turbo box and a shift kit for my vl
dont get a turbo box unless you need it
A shift kit will make it shift harder and crisper than standard and extend the life of the auto because its the sloppy shifts that stock autos have that create strain and wear. But note that it will put extra strain on your tailshaft and diff (kaboom).
You'd be better off converting to manual, unless you really want to stick with the auto. The manual with a good clutch has less driveline loss and is generally alot more pokier. Same goes with most cars though I guess. I know vn manuals are little monsters
the vn autos are pretty good i think, they have never missed a shift for me
so not a good ider then for a turbo box and shift kit
Just unnecessary mate.. You can go the shift kit if you want to stick with the automatic, but I'd personally say you'd notice much more of a difference with a manual conversion.
I'd consider some other mods before upgrading the automatic. Exhaust, Extractors, Cam, Headwork, Shave the head etc.
Bugger the shift kit, get your auto manualised instead.
KEAS are the people to see for this.
You'd probably be better off investing the money in some English tutoring dude![]()
